diyAudio Sponsor
Old 26th November 2011, 02:11 AM   #1
Default amplifiers audio research D90
hello
please can you help me, I have an audio amplifier research D90 and I need to know if the 4 ohm output is connected to ground, you can switch to 4 ohms speaker? thank you very much regards
Old 26th November 2011, 03:35 AM   #2
it looks like it is. here is the schematic. you can confirm by unplugging the amp , disconnecting the speakers...and use an ohm meter between the 4 ohm tap and the chasis...it looks like it will read zero ohms.
Old 26th November 2011, 10:43 PM   #3
asmith is offline asmith  United States
Default Yes it's grounded
Audio Research had a worning for many years printed right on the back of the amp that stated that the 4 ohm tap was grounded, not to conect to switching circuts ect.
Old 26th November 2011, 10:50 PM   #4
Audio Junkie
Zero Cool's Avatar
Yes the 4 ohm tap is grounded but the "0" output is NOT! so YES you can use 4 ohm speakers!
It's not about what you can BUY...It's about what you can BUILD!
Old 26th November 2011, 11:07 PM   #5
kevinkr is online now kevinkr  United States
kevinkr's Avatar
Exactly correct. Noting caveat mentioned in a previous post.
www.kta-hifi.net
Old 27th November 2011, 11:56 PM   #6
Default D90b
hello thanks, then I can been disconnected on 4 ohm common ground, and use 4 ohm speakers? no problem, would have to adjust bias, or will I have problems with feedback, sorry my question again, Regards
Old 28th November 2011, 01:01 AM   #7
kevinkr's Avatar
You do not need to, nor should you change any of the connections on the secondary side of your output transformers. All you need to do is connect your speakers between the 0 ohm and 4 ohm taps, that's it..
No bias adjustment is required for use with 4 ohm speakers either.
If you disconnect the 4 ohm tap from ground the amplifier will not operate and will become extremely hazardous as some percentage of the output stage B+ will then appear on the output terminals.
www.kta-hifi.net
Old 28th November 2011, 02:18 AM   #8
Audio Junkie
Zero Cool's Avatar
I think he is trying to say that he understands not to connect any of the taps to ground. the wording is just not exact.
Old 28th November 2011, 02:27 AM   #9
kevinkr's Avatar
I'll keep my fingers crossed and hope that he understands..
www.kta-hifi.net
power d90-b pancho montecinos Tubes / Valves 2 21st November 2011 02:28 PM
Voltage Change9115v/230v) of Audio Research amplifiers martev Tubes / Valves 0 16th August 2011 06:42 PM
Research on switched audio amplifiers sovadk Class D 4 9th February 2006 06:57 AM
pro amplifiers vs. home audio amplifiers bonsai171 Solid State 26 25th February 2004 08:24 PM
Audio Research D90 - Info JDeV Tubes / Valves 7 29th April 2003 12:08 PM
Page generated in 0.12079 seconds (69.07% PHP - 30.93% MySQL) with 11 queries
