diyAudio Sponsor
Old 23rd November 2011, 09:37 PM   #1
Default single stage amp?
Is it possible to build a single stage amp that has a transformer on the input?
Could the a concentional source drive such an amp?
Old 23rd November 2011, 10:02 PM   #2
Vinylsavor's Avatar
The usage of an input transformer has nothing to do with the number of stages, so yes it can be done. Can a conventional source drive it. IME not so well. Depends on the transformer (step up ratio) miller cap of the tube and the output impedance and type of output stage of your source
http://vinylsavor.blogspot.com/
Old 23rd November 2011, 11:37 PM   #3
Depends a lot on what kind of tube you intend to use.
A 6C45P will do nicely, with no input transformer.
Old 24th November 2011, 08:15 AM   #4
Leonid is offline Leonid  Russian Federation
Одноламповый усилитель на 6П9
But, R3 - 500 Ohm
Old 24th November 2011, 09:11 AM   #5
Vinylsavor's Avatar
Hi!
The 6HS5 works nicely in a single stage amp too:
VinylSavor: Tube of the Month: The 6HS5
7-8W SE. Needs about 2.75V RMS at it's input for full power out. This could be reduced to more common 0.75-1V with a step up input transformer. But since many sources and preamps have way too much gain, an input transformer would not be needed in most cases.
Thomas
Old 24th November 2011, 12:24 PM   #6
The 6HS5 seems super interesting! For me especially for ESL direct drive applications. It's just too bad I'm already addicted to the directly heated sound.
If you use parafeed, your options open up a bit more, as some of these medium mu small transmitter triodes have a high Rp, and would be impractical with an OT. Plus they've got that DHT magic if that's up your alley.
IV single stage inverting Feedback Amp ccschua Tubes / Valves 18 6th July 2009 01:09 PM
Single stage (sort of...) McPhono amp Onvinyl Solid State 19 21st February 2009 08:21 PM
Single Stage Line Amp (Diff Amp) Tube? AudioAngel Tubes / Valves 9 28th November 2006 11:38 AM
5687 as a single stage SE amp simonov Tubes / Valves 4 15th November 2006 09:26 PM
Single Stage power amp. lumanauw Solid State 10 2nd April 2004 09:03 AM
Page generated in 0.10410 seconds (64.78% PHP - 35.22% MySQL) with 10 queries
