Making Spice Models for tubes - Page 2 - diyAudio
Old 6th December 2012, 04:02 PM   #11
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
I recently found this topic using Google and it is pretty interesting. Do anybody if it can work also with pentodes?
Many thanks in advance.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 29th January 2013, 03:10 PM   #12
Other question/problem I have with regards to the tube models is that the ones I have come across do not have a equivalent Noise resistance at the input for simulating S/N ration in the circuits I work on (RIAA).
Does anyone know how I can add a Equivalent Noise Resistance of 350 ohm (Worst Case) to the spice model of the 6N23P below?
.SUBCKT 6N23P 1 2 3 ; P G K ; P G C (Triode) 26-Oct-2001
+ PARAMS: MU=33.04 EX=1.220 KG1=212.4 KP=183.83
+ KVB=300.0 VCT=0.00 RGI=2000
+ CCG=3.6P CGP=1.5P CCP=2P
E1 7 0 VALUE=
+{V(1,3)/KP*LOG(1+EXP(KP*(1/MU+(V(2,3)+VCT)/SQRT(KVB+V(1,3)*V(1,3)))))}
RE1 7 0 1G
G1 1 3 VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG1}
RCP 1 3 1G ; TO AVOID FLOATING NODES IN MU-FOLLOWER
C1 2 3 {CCG} ; CATHODE-GRID;
C2 2 1 {CGP} ; GRID-PLATE;
C3 1 3 {CCP} ; CATHODE-PLATE;
D3 5 3 DX ; FOR GRID CURRENT
R1 2 5 {RGI} ; FOR GRID CURRENT
.MODEL DX D(IS=1N RS=1 CJO=10PF TT=1N)
.ENDS
Old 8th March 2013, 03:29 AM   #13
jazbo8's Avatar
If you already know the ENR, then you can calculate the noise figure based on the stage's configuration, it does not need to be "inside" the tube model, the methodology is outlined in Burkhard Vogel's "The Sound of Silence".
Jaz
Old 8th March 2013, 07:53 PM   #14
Thanks Jaz
Yes you are right found the chapter in the book you refered to... thanks for the hint!!!
Cheers Tonny
Spice Models for Tubes w Screen Grid by Gurski jackinnj Tubes / Valves 0 26th January 2011 07:47 PM
Spice models stinius Solid State 0 18th November 2008 09:07 PM
Any spice models around for AA5-esque battery tubes? aletheian Tubes / Valves 2 30th March 2007 12:35 AM
Spice Models Bonsai Solid State 5 24th September 2003 09:44 AM
Copyright 1999-2017 diyAudio
