diyAudio Sponsor
Old 21st November 2011, 04:29 PM   #1
Default Valve amplifier identification
Hi , Anyone ID this amp for me? I've no idea so far on the manufacturer or the model. Any info appreciated, Vince
Old 21st November 2011, 04:36 PM   #2
kevinkr is online now kevinkr  United States
kevinkr's Avatar
I'm thinking this is a LEAK TL-12 - the very early version, and quite valuable if that is the case.
Edit: No I guess not, but definitely of UK provenance.. The transformers and general layout are wrong, although the construction details look very similar.
www.kta-hifi.net
Old 21st November 2011, 04:38 PM   #3
SY's Avatar
Looks much like a Leak TL-12.
edit- xpost with Kevin. GMTA
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 21st November 2011, 04:53 PM   #4
GloBug is offline GloBug  Canada
Banned
Looks like it could be a Allen Organ amp, although usually these are labeled.
Old 21st November 2011, 05:05 PM   #5
DF96 is offline DF96  England
Not a TL-12, unless that was made in two different versions with different layout and valves. It doesn't correspond to any of the amps in Stephen Spicer's book. Lineup appears to be EF86, ECC83, 2xKT66, GZ34. Classic 1950's design, though.
Old 21st November 2011, 05:15 PM   #6
PDL is offline PDL  United States
Not an Allen, made in Great Britain. Tubes have European id's (GZ34 vs 5AR4). Transformers are not potted Acro's. Construction and color does appear similar though.
Old 21st November 2011, 05:32 PM   #7
SY's Avatar
Layout is different, but the TL-12 schematics I dug up were 5-20 with EF86 and ECC83. The gold color and construction style are suggestive.
Leak TL/12 50'th Anniversary
Old 21st November 2011, 06:45 PM   #8
Never seen one quite like that, has shades of Pamphonic, so could be a special made specifically for the US market?
Old 21st November 2011, 06:48 PM   #9
According to Spicer, the TL/12 had EF37 and ECC33. Pictures show all valves in one row along the edge of the chassis. The circuit SY linked to appears to show EF36 and ECC33. Note the top cap for the first stage grid.
Old 21st November 2011, 10:34 PM   #10
Guys, EMI Orthotone STD 373 has been suggested. Attached are pictures from the underside if this helps. Vince
Valve Amplifier sacpul Tubes / Valves 7 29th July 2009 07:04 PM
Amplifier identification -=terran=- Tubes / Valves 3 10th November 2006 04:09 PM
Kustom Amplifier Speaker Identification tekniderm Instruments and Amps 4 20th June 2006 12:22 AM
Valve Identification-Help hifileslie Tubes / Valves 21 17th April 2005 08:04 PM
Page generated in 0.14502 seconds (66.25% PHP - 33.75% MySQL) with 11 queries
