E-M-field problem
E-M-field problem
Old 21st November 2011, 11:48 AM   #1
briansune is offline briansune  Hong Kong
Default E-M-field problem
Hey do any one know the affection of EMF between transformer, cause I'm going to put all the component together@@.
So i would like to show the design. Hope some one could he me on this> THANKS
Old 21st November 2011, 05:56 PM   #2
payitforwardeddie is offline payitforwardeddie  United Kingdom
If I was building this, I would leave the output transformers where they are and move the Inductor (Choke) and the Mains transformer over to the right. Keep the air gap of the Inductor (Choke) to the edge of the box.
Old 21st November 2011, 06:33 PM   #3
Ya you are right this may reduce the EMF affection between the output and choke or main transformer. Bur the look of this will become a little odd.~~ But thanks for your ideas~
Old 21st November 2011, 06:49 PM   #4
Sorry for the typos
Old 21st November 2011, 08:10 PM   #5
hemgjord is offline hemgjord  Sweden
The general rule of thumb when placing inductive components tightly together is to orient the coils 90 deg from each other.
/Olof
I'm not allowed to do magic, union rules...
Old 21st November 2011, 09:22 PM   #6
do you mean each of the transformer should shift 90 deg to each other?
Old 21st November 2011, 09:29 PM   #7
GloBug is offline GloBug  Canada
Banned
Yes the coils should be 90 degrees in relation to each other.
Old 21st November 2011, 11:24 PM   #8
Do you mean this??Click the image to open in full size.
Old 21st November 2011, 11:50 PM   #9
Palustris is offline Palustris  United States
Palustris's Avatar
That's correct for orientation, but the point was made that the choke should be in the corner not in the center and the same with the PT; so put them over on the left edge. If you are using a rectifier tube it can probably go between the two PS transformers. The output transformers will be between your highest EMF generators and your signal tubes which will be in the space to the right. Distance is everything with the EMF so put your PS as far as possible from your signal components; that's just basic good layout practice.
Old 22nd November 2011, 12:59 AM   #10
YA but i'm not quite sure the terms of PT PS transformers
And the highest EMF generator will be the Main power transformer~
E-M-field problemHide this!Advertise here!
Carver TFM-55X Mag field PS regulator problem nites Solid State 22 24th May 2011 05:48 AM
Near field vs Far field Audist Multi-Way 17 25th May 2007 08:44 PM
Near field / far field? 2litre Multi-Way 4 2nd January 2006 10:44 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 02:21 PM
Copyright ©1999-2017 diyAudio
