diyAudio Sponsor
Old 20th November 2011, 07:59 PM   #1
stefa38 is offline stefa38  Italy
Default Do you know these capacitors?
I do not know the working voltage.
Thanks in advance
Old 20th November 2011, 08:28 PM   #2
DF96 is offline DF96  England
The green one is probably Mylar dielectric (a type of polyester). Not sure about the others.
Old 20th November 2011, 08:32 PM   #3
thaumaturge's Avatar
Unmarked ceramics like that are usually 50V.
Doc
Ne timeas a facie mulierum ea ignorare
Old 20th November 2011, 09:23 PM   #4
KatieandDad's Avatar
They are marked in PF
3200pF
390000pF
47000pF
As for voltage - assume the worst - 63V
used capacitors doktor Parts 2 11th September 2010 04:40 PM
what is the difference between silver mica capacitors and ceramic capacitors ?? prorms Solid State 1 6th May 2008 12:38 PM
Continental Capacitors' "Type-A" oil-filled capacitors? radical Parts 0 21st October 2004 08:39 PM
capacitors: panasonic FC vs elna RJH vs rubycon ZA capacitors costiss Parts 11 30th January 2003 09:32 PM
differences between computer grade capacitors and small can capacitors LBHajdu Pass Labs 0 22nd February 2002 01:29 AM
Page generated in 0.10660 seconds (53.18% PHP - 46.82% MySQL) with 11 queries
