diyAudio Sponsor
Old 20th November 2011, 02:32 AM   #1
ryuji is offline ryuji  United States
Default 807/6au6 pure pentode mode amplifier
I had to take a vacation from tube amplifier fiddling after my life got too busy. Im back at it. I drew this up some time ago, but i just now got to wire it up in a prototype form. Best sounding circuit I've yet to listen to. Compared to a triode driver/preamp this tube is far more precise/articulate without losing the part that makes tube amplifiers awesome
Old 20th November 2011, 02:35 AM   #2
Following up my sharing with a question. Anybody put together a 6au6 line level amplifier or have an idea of how to go about designing one? I want to build a tube buffer for my subwoofer channel that is partially for balancing the volume with the main amp. is it as simple of copying my circuit as seen above and using a voltage divider on the other end to attenuate it down to line level voltage?
Old 20th November 2011, 07:47 AM   #3
dgta is offline dgta  United States
No, a buffer has unity gain and is typically a cathode follower. You can use a tube stage with lots of gain and then attenuate it, but it's a very poor way of making a buffer.
Old 20th November 2011, 02:18 PM   #4
DF96 is offline DF96  England
The unbypassed 807 screen grid resistor will give it some of the characteristics of UL, so not pure pentode mode. Whether better or worse I cannot say, but certainly different. By the way, the 807 is not a pentode but a beam (kinkless) tetrode.
Old 20th November 2011, 04:42 PM   #5
i was actually considering bypassing it, i dont have parts on hand to do that tho, need to order some. using up my stock of 10 uF caps on building the gain stage
maybe that feedback is desirable tho. ill have to carefully compare them. my quick and dirty test used a 10k resistor in there(as thats what is installed at this moment)
and yea, i guess your right on it being a beam tetrode.
i was actually told in the past that as my 300v supply is regulated that the bypass on the 807 screen wasnt needed. i was going to compare but you agreeing with my original thoughts changes my mind back on that decision
going to rip apart my amp and rebuild it as described in the schematic this coming week, ill report my findings with experimentation and actual b+ voltage
Old 20th November 2011, 08:35 PM   #6
A screen grid is both an input and an output. If you are lucky, the signal voltage developed across the g2 resistor will move the valve more towards triode-mode operation. If you are unlucky, you will get extra harmonics and IM as the signal, in effect, goes through the valve twice.
Old 20th November 2011, 08:44 PM   #7
what are your thoughts on directly connecting g2 to my 300v regulated supply, this gets around the whole problem? or is it better practice to use a bypassed resistor
Old 20th November 2011, 08:51 PM   #8
A small resistor might help maintain stability, by acting as a stopper. Apart from that, a fixed DC voltage will enable true 'pentode' mode operation.
Old 20th November 2011, 08:53 PM   #9
so in other words you like the idea of ~2.5k resistor there with an 10uf or so bypass like i assembled the 6au6
resistor i guess in theory helps prevent oscillations
I should try it out as each... who knows, like you said you get varying results and i might in fact enjoy one of them.
anything else i should experiment with? perhaps bypassing the cathode resistor on the driver?
Old 20th November 2011, 08:55 PM   #10
2.5k is not small, in this context. If you want 'pentode' sound then either bypass the resistor, or put a 100-200 ohms to the supply.
Driver for a 807 em triode mode...help !!! aldovan Tubes / Valves 7 4th October 2011 06:15 PM
What is grid resistance of 807/6l6 in pentode ryuji Tubes / Valves 9 4th May 2011 09:52 AM
PP pentode tube headphone amp PCB needed ( 6au6 thru el84) speakerfritz Tubes / Valves 5 28th November 2010 01:24 AM
6AU6 Aikido in Triode mode? Original Burnedfingers Tubes / Valves 6 1st December 2008 04:50 PM
Using a spdt switch to select between triode mode and pentode mode on a guitar amp. G Tubes / Valves 19 15th March 2006 09:15 AM
Page generated in 0.15125 seconds (62.13% PHP - 37.87% MySQL) with 10 queries
