| diyAudio Sponsor | ||
Simple question- wiring up an amp but my actual tubes are in storage, so I can't easily inspect one.
Datasheet for 6DE4 indicates pin 2 is an internal connection, and says do not use 1, 4, or 6. I would like to use pin 6 as a junction. I do recall my 6DE4's only have a few pins brought out of the base, so this shouldn't be a problem. Does anyone have a 6DE4 to inspect and let me know if pin 6 is actually brought out of the base? Thanks a bunch- |
#2 |
I have a 6DA4. Datasheet says the same thing. There is a pin 2 that appears connected to something. Pins 1, 4, and 6 are missing.
http://www.ecpaudio.com |
#3 |
Suspected so. Thanks for the confirmation.
| z-5300 sub pins | superxpro12 | Subwoofers | 3 | 7th January 2012 03:02 PM |
| EL84 Unused pins safe to connect? | rotaspec | Tubes / Valves | 4 | 15th January 2010 09:49 PM |
| 74ac02 unused input pins | tonitze | Digital Source | 19 | 23rd April 2005 02:41 PM |
| why multi pins ? | 6SN7GT | Tubes / Valves | 9 | 10th July 2004 01:46 PM |
| lm pins | theChris | Chip Amps | 0 | 26th April 2003 10:32 PM |
| Page generated in 0.18922 seconds (29.51% PHP - 70.49% MySQL) with 10 queries |
