diyAudio Sponsor
Old 18th November 2011, 10:49 AM   #1
rvrazvan's Avatar
Arrow amp with SRPP output stage? post if you know one
Came across this schematic a few days ago, and i was wondering if anyone here has more experience with similar desing, using other triodes (more power?).
Old 18th November 2011, 06:50 PM   #2
aardvarkash10's Avatar
how about this?
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012
Old 25th November 2011, 08:33 PM   #3
payloadde's Avatar
I am curious ...
What is the purpose of the EF80 in the middle ?
Stabilize the DC operating point ... ? How ?
I did some recalibration on the resistor networks to accomodate a pair of PL504.
And some other modifications like NFB and xfrmr hookup.
Seems to work well.
The adjustment of the standing current is very sensitive though - may easily run away.
Judge: This court appreciates that you invented physics, Mr.Newton, but unfortunately you can't have a patent on it.
Old 25th November 2011, 10:50 PM   #4
This is not SRPP this is SEPP .
Old 27th November 2011, 06:30 AM   #5
yeah, but its as close as you're going to get...
Old 27th November 2011, 04:53 PM   #6
tubemax is offline tubemax  Netherlands
How about this one > SRPP 6AS7(6080)...
Max
Old 27th November 2011, 07:29 PM   #7
Irakli is offline Irakli  United States
Irakli's Avatar
I made one just for fun. Here is the thread
EL86 Single Ended PP Power Amplifier
I will not recommend making SRPP power amplifier though.
My System
Old 27th November 2011, 11:32 PM   #8
Originally Posted by payloadde View Post
I am curious ...
Seems to work well.
The EF80 is there to feed the upper PL36 with reversed signal, 180 degree out of phase from the lower PL36 .
Old 28th November 2011, 09:04 PM   #9
payloadde's Avatar
of course ! ... didn't catch this because I was thinking in terms of SRPP which is self-inverting.
Old 28th November 2011, 09:14 PM   #10
payloadde's Avatar
Originally Posted by aardvarkash10 View Post
how about this?
this circuit claims 18W and it does so ... however
at Pout over 10W the upper tube seems to fight the lower tube,
so at 15W the upper tube shows plate dissipation of 30 W average
and 80W peak. A lot even for a sweep tube.
this doesn't happen at lower output ...
usual SRPP style circuits don't do that, actually dissipation drops when overdriven.
expect red glowing plates during sine wave testing.
music program may be just O.K. though
Latest project SRPP valve front end with class D MOSFET output stage. nigelwright7557 Tubes / Valves 0 21st March 2011 11:06 PM
My Take on an SRPP Output Stage amc184 Digital Source 11 5th March 2010 11:20 PM
SRPP with FETS, what output stage? davidallancole Solid State 18 4th January 2008 05:39 PM
6as7 SRPP output stage Molloy Tubes / Valves 4 15th September 2006 05:39 PM
Audio Note DAC4 SRPP output stage problems! bbakota2000 Tubes / Valves 5 12th June 2005 12:25 AM
Page generated in 0.15416 seconds (61.31% PHP - 38.69% MySQL) with 11 queries
