diyAudio Sponsor
Old 18th November 2011, 10:47 AM   #1
Default Output transformer question
I have a small amp using the 6c45pi. The output transformer has 4 and 8 ohm taps but I am considering hooking a 32 ohm speaker to it. Assuming
I am getting 1w into 8 ohms what should my output be into 32 ohms.
Old 18th November 2011, 09:16 PM   #2
1w into 8 ohms needs 2.8volts. 2.8 v into 32 ohms gives 1/4 watt.
Power = volts x amps
Power = volts squared divided by resistance
Power = amps squared times resistance
Old 19th November 2011, 12:57 AM   #3
Gilgy is offline Gilgy  United Kingdom
Why?
Old 19th November 2011, 02:20 AM   #4
aardvarkash10's Avatar
disregarding the shift in the operating point of the output tube due to the change in the reflected impedance...
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012
Old 19th November 2011, 01:10 PM   #5
DF96 is offline DF96  England
Yes, it all depends on the output impedance (which is the triode anode impedance transformed by the transformer). Without knowing this you can't do an exact calculation. However, some reduction in output power is likely.
Output transformer question Doogie Tubes / Valves 10 25th January 2011 08:57 PM
Output transformer Question keithgreenhalgh Tubes / Valves 14 3rd August 2008 02:42 PM
Output Transformer Question? Cloth Ears Tubes / Valves 9 3rd April 2007 04:37 PM
1:1 output transformer question Tyimo Solid State 31 16th January 2007 01:14 PM
Page generated in 0.18784 seconds (37.19% PHP - 62.81% MySQL) with 10 queries
