diyAudio Sponsor
Old 17th November 2011, 11:42 PM   #1
Bigun is offline Bigun  Canada
Bigun's Avatar
Default can SE driven PP be clean enough to sound SE ?
What I mean to ask is - assume a SE input stage, which lends a SE harmonic signature to the signal. And assume a PP output stage (transformer phase splitter) based on DHT. Since DHT is very linear and low distortion it will not dominate the harmonic signature of the amp. You get higher power from use of PP but sonic signature is still SE (from input stage).
Pipedream ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 17th November 2011, 11:47 PM   #2
aardvarkash10's Avatar
less pipedream than a catalog of sweeping generalisations... Care to get more specific?
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012
Old 17th November 2011, 11:56 PM   #3
rvrazvan's Avatar
try a SRPP output stage . with 6as7g for example
(pp without pp harmonic structure)
Old 17th November 2011, 11:59 PM   #4
Bigun's Avatar
I have always thought that a tube amp should be SE throughout, for the best 'sound' but it has the disadvantage of less power efficiency compared with PP and an inability for hum cancellation that exists between two DHT output tubes with heaters in opposite directions. So I'm just wondering if I can get the best of both worlds, an amp with the benefits of PP operation at the output but the sound of a SE amp.
However, just found this link, which says it may not be possible...
http://homepage.mac.com/tlinespeaker...v-PP-Part2.pdf
some 'people' say SRRP doesn't sound good. Broskie says SRPP is best used where it drives a load of known/constant impedance which a speaker is not. So I'm not confident in using an SRPP output.
Old 18th November 2011, 12:18 AM   #5
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Default Hysteristis curve...
What was that about the hysteristis kink in the SE iron, makes the perfect transfer of + = - in an AC signal................
__________________________________________________ _____Rick..............
Old 18th November 2011, 12:21 AM   #6
ChrisA is offline ChrisA  United States
I don't think you can do it. I think the sound of a SE amp is because of the added second harmonics, those cancel in a PP amp
If you want that tube sound but need 10,000W to fill a sports stadium do what the big guys do. They use a small tube amp and put a dummy load on the speaker terminal then tap off that load and run it it a huge stack of class D amps.
So if yuo want the sound of an SET but 10X more power, build an SET, the smallest one you can then atenuate the output and feed it t a solid state amp
Or do what many others do, build speakers that are easy to drive with 5W
Old 18th November 2011, 12:25 AM   #7
Bigun's Avatar
the 2nd harmonics generated by the triodes in the PP output cancel, but the 2nd harmonics generated by the input stage should be preserved by the PP output.
another interesting link. SE sounds better here; but it's hardly an apples to apples ! http://www.youtube.com/watch?v=fKq8_aw4thw
Old 18th November 2011, 01:15 AM   #8
chrish is offline chrish  Australia
chrish's Avatar
Sounds like you want a second harmonic distortion generator. You should be able to build a simple line stage to attach to the front end of your system with a pot to increase/decrease the distortion to give you the effect you want.
If you specifically want a single ended front end, there are plenty out there, you could just use a different operating point of the input triode to increase the second order distortion to suit your taste. Here is just the firs random schematic I found with a single ended front end to PP finals:
Old 18th November 2011, 02:08 AM   #9
Pano is offline Pano  United States
Pano's Avatar
I've heard a couple of 300B P-P that were very nice. So why not?
Old 18th November 2011, 10:27 PM   #10
DF96 is offline DF96  England
The signal level in the first stage will be much smaller than an output stage, so distortion will be small unless the circuit is poorly designed. If you want 'SE sound' then you need to either design it for the wrong bias, or use a bigger signal and then attenuate it.
How about even simpler with good clean sound? thaumaturge Solid State 25 16th August 2011 12:48 AM
SE 2 watt clean amp? johnr66 Tubes / Valves 27 14th December 2010 05:37 PM
What makes a amplifier sound clean? chipper Car Audio 10 23rd October 2010 07:47 PM
clean, wrm, sweet sound amp CLass A space2000 Solid State 64 11th May 2008 05:01 PM
Why some amp sound sweet and clean? space2000 Solid State 0 7th May 2008 07:53 AM
Page generated in 0.64794 seconds (14.47% PHP - 85.53% MySQL) with 11 queries
