| diyAudio Sponsor | ||
Hi!
Just recently I purchased a second-hand Audioromy Fu29. My Lowther Fidelio's with DX3's don't really need that amount of power. I have tested Single-end on them, and it is hard to forget the sound that came from them that time! Do anyone got the knowledge to tell me if it is doable to convert the push-pull Audioromy Fu29 to SE, and what's needed? Somewhere on the internet I read that the Fu29/ Gu29/ 829b should be capable of about 10W in triode mode. Any input is appreciated. Best regards, John |
#2 |
Major work, Plus the cost of replacing the O/P Transformer for a proper SE one....
No worth it, Sell and buy a proper SE amp....
Das Beste Oder Nichts |
#3 |
Thank you for your reply. I will keep this one until there is a SE Audioromy Fu13 or a pair of SE 300b monoblocks up for sale somewhere. They are both discontinued over there in china..
#4 |
While not particularly practical, if it is operating in class A you can disable the drive to one output tube and run the other SE class A. The sites I've seen indicate it is in class A, however the normal class A amp may parallel both halves of the tube. Therefore you will not get as much out if you disable drive to one side of each PP pair as you would running both sections in parallel SE.
| New 300B single end | Musik007 | Twin Audio | 61 | 13th March 2011 04:50 PM |
| anyone help convert dual volume to single? | awangotango | Tubes / Valves | 11 | 10th December 2010 12:36 AM |
| How should I convert my single Fe103 based RS speaker to a portable sound device? | Spasticteapot | Full Range | 2 | 16th October 2006 03:56 AM |
| Convert single to dual supply | Wombat2 | Power Supplies | 19 | 17th July 2006 02:44 PM |
| Page generated in 0.09769 seconds (62.28% PHP - 37.72% MySQL) with 10 queries |
