| diyAudio Sponsor | ||
I have a SE amplifier with some sort of autobias. I don’t have any schematic. I would like to check what the bias is without taking the box apart.
I think this: Tube-Town Online-Store - Bias-Messadapter Oktal, Fertigadapter tt-probe8 has a 1 ohm in series with the cathode. Would this affect any known autobias circuits so my measurements will be incorrect? |
#2 |
Do you mean bias or idle current? These terms are often interchanged but have VERY different meanings. Idle current can be determined by measuring the voltage from cathode to ground, then dividing by the resistance from cathode to ground. Bias is the voltage between cathode and grid and can usually be measured directly.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 |
Well, the adaptor I'm referring to is described to be used for bias. But in your terms it seems like I would like to test the idle current. What I want to check is that the autobias gives me a good working point - what ever that might be.
#4 |
If the adapter has 1 ohms resistor in series with the cathode, then it does not affect to any autobias circuit and the result is correct.
#5 |
Terminology: You ARE setting bias. But you're MEASURING idle current, which is controlled by the bias voltage. And typically you don't care what the bias voltage is - you want to set an operating point at a specific current.
#6 | |
To put this in perspective, in the tube era, before transistors, parts with tolerances better than 10% were rare. |
#7 |
Thanks for making it clear.
| Bias Measuring points, pros cons | Zero Cool | Everything Else | 4 | 18th November 2011 06:49 AM |
| Dynamic Bias - Active Bias - Automatic/Self biased - Overview wanted | tiefbassuebertr | Pass Labs | 11 | 5th May 2011 08:42 PM |
| Bias problem- 1 Socket shows extremely low bias! | otokomae | Tubes / Valves | 12 | 31st December 2008 10:01 PM |
| Stray hum pickup *preamp* cathode R-bias vs. battery bias & 12AU7vs.5687 | awedio | Tubes / Valves | 2 | 19th April 2008 01:30 AM |
| Favorite bias measuring and metering methods? | audiobot | Tubes / Valves | 14 | 15th March 2004 11:13 PM |
| Page generated in 0.11770 seconds (67.17% PHP - 32.83% MySQL) with 10 queries |
