Old 26th January 2012, 08:13 AM   #11
M Gregg is offline M Gregg  United Kingdom
M Gregg's Avatar
Originally Posted by DF96 View Post
Sounds more like protection circuitry than reservoir caps.
I agree,
Is there any regulation in this amp..could be cutting out on overcurrent or thermal overheat?
M. Gregg
What is the sound of one hand clapping?
Old 26th January 2012, 08:15 AM   #12
M Gregg's Avatar
Originally Posted by devilsindetails View Post
Gets the typical "thump" at speaker output after startup delay (signal output for five seconds) and then thumps again cutting out one channel, then another thump cutting out the other channel.
That seems to tell me the caps are energizing and discharging too quickly on startup and then losing whatever capacitance they have entirely. Yes ? No?
Have you measured the power rails when this happens?
I would have thought that bad caps would cause hum and /or short..
M. Gregg
Old 26th January 2012, 09:03 AM   #13
M Gregg's Avatar
The only other thought,
I guess the heaters remain on during this fault?
M. Gregg
Old 5th April 2012, 08:58 AM   #14
Take a look at the assembly manual/schematic for the Assemblage ST-40. Looks like the power amp part is essentially the same
Old 17th April 2012, 12:44 AM   #15
devilsindetails's Avatar
Originally Posted by Braga View Post
They look exactly the same as the SFS 40 power amp. main caps.
Value is 1700uF/300 V x 2 in series.
Yes you were right. Once I removed the caps the values were marked on the IC board. Replaced them with 1500uf/300 V x 2 in series but after working flawlessly for about 6 hrs...then a new problem and new symptoms....distortion ( mid-pitched motorboating) both channels.....
I have yet to see any problem, however complicated, which, when you looked at it in the right way, did not become still more complicated. (Poul Anderson)
Old 17th April 2012, 12:55 AM   #16
Thanks...no the cap values, among many others, are quite a bit different. But thanks again....
Old 17th April 2012, 01:03 AM   #17
DF96 & M Gregg. Thks...for some reason I missed any notifications about your responses to this thread...as you know from previous posts I am (was) relatively inexperienced with Tube (Valve) DIY'selfing and have been working with that little SE EL84 Amp, which I used to replace my Sonic Frontiers Amp after it commenced acting so strangely.
I'll follow the investigative avenues you both suggest.....thanks again fellows!
Sonic Frontiers Jitterbug eleakist Digital Source 2 11th February 2008 04:23 PM
Sonic Frontiers Line 2, please help? henkel Tubes / Valves 2 23rd December 2006 04:40 PM
Sonic Frontiers Power 2SE sonic Tubes / Valves 1 21st June 2004 03:19 PM
What happened to Sonic Frontiers, exactly? KT Everything Else 8 27th May 2004 11:35 AM
Sonic Frontiers and Iris martioz Digital Source 0 17th March 2003 09:56 AM
Copyright ©1999-2013 diyAudio
