What is screen tap of transformer?
Old 16th November 2011, 12:21 PM   #1
diyroger is offline diyroger  United States
Banned
Default What is screen tap of transformer?
Hello I'm new to tube. Now I'm planning to build my first tubeamp. The most difficult part of building a tube amp is wiring the transformers. Can any one tell me what is screen tap of a output transformer? I read this in an artical about how to make transformer, but don't have idea about what it is at all.
Old 16th November 2011, 12:34 PM   #2
20to20 is offline 20to20  United States
20to20's Avatar
Search for info on the subject of "Ultra-Linear". The origins are from Acro Products.
Old 16th November 2011, 12:47 PM   #3
toprepairman is offline toprepairman  United Kingdom
Perhaps something a bit simpler and less potentially (in both senses) lethal might be a wise approach to learning something new.
Old 16th November 2011, 02:29 PM   #4
FullRangeMan is offline FullRangeMan  Brazil
FullRangeMan's Avatar
It is the output of the electrostatic shield to be grounded.
>Never go to a psychiatrist, adopt a cat or dog from the streets. On the streets pets live only two years average.
Old 16th November 2011, 02:32 PM   #5
aeandm is offline aeandm  Ukraine
Hello, this is difficult .
Only mode is putting power transformer a great distance away .
Axis all transformers 90degree .
atandm
Old 16th November 2011, 03:06 PM   #6
DF96 is offline DF96  England
No. Screen tap is a winding tap for the output valve screen grid, also known as g2.
Wiring the transformers is not the most difficult part of building a valve amp. Proper grounding, for both safety and noise, is probably the part which people most often get wrong. The mains side of the transformer is the most important part to get right, as getting this wrong can have serious life-threatening consequences.
Old 16th November 2011, 03:44 PM   #7
Thanks for informing.
Old 16th November 2011, 07:53 PM   #8
speakerfritz is offline speakerfritz  United States
to keep things simple...PP output transformers can have 3 primary taps or 5 primary taps. Transformers that only have 3 primary taps are not capable of being used in amps configured for ultra-linear mode unless resistors are used between g1 and g2. transformer with 5 primary taps allow the amp to run in ultra-linear mode by connecting the 40% tap to g2. Not all designs require transformers that can support ultra-linear mode.
Old 16th November 2011, 08:36 PM   #9
Excuse me,I think You speak screening fields around transformers.
On power You make sectional is important for "out power". When You Uanode=1000V+600induction V between coil winding must are electrical strength
or screen. Here isn't simple solutions.
aeandm
Old 17th November 2011, 09:03 AM   #10
payitforwardeddie is offline payitforwardeddie  United Kingdom
I am surprised that people are not killed attempting this.
What is screen tap of transformer?Hide this!Advertise here!
screen tap on OPT hirafu_boarder Tubes / Valves 1 29th September 2010 10:26 AM
NFB capacitor to screen tap on ST-70 ? zigzagflux Tubes / Valves 10 17th November 2006 11:36 AM
transformer with no center tap traw Parts 0 3rd June 2006 02:36 AM
20% versus 43% screen tap ecl8220% Tubes / Valves 10 4th November 2005 09:16 PM
Transformer Center Tap dswiston Parts 2 4th February 2004 03:09 PM
Copyright ©1999-2017 diyAudio
