I've always thought that 3C24's were cool looking light bulbs....
Example: Audio Asylum Thread Printer
~Tom
~Tom
Hello Tyne,
The 812A has a Thoriated-tungsten-filament and illuminates very brightly but is seldom used in audio work. I have a pair that some day I will play with. These direct heated power triodes were most commonly used in early modulators, AF pwr amps and transmitting RF application back in the 1940's. Mickeystan
Most thoriated tungsten filaments are rather bright. The 211 and the 845 light up rather well.
845 - looks like a light house......10V @ 3A is 30 Watts of glow.
Actually its 10 volts at 3.25 amps. There is two of them running here. That and the computer monitor are the only lights in the room.
GM-70. 20V@3A = 60W, almost like light bulb...
The 833A has a 10 volt 10 amp filament for 100 watts, but it also makes a good room heater.
- Tubes / Valves
- Brightest heaters in tubes?
