| diyAudio Sponsor | ||
Hello All,
I am upgrading the OPT's on my 6V6SE. My new OPT's have a 40% tap, my old ones did not. On the schematic you can see a 100R resistor tied to the plate and 2nd grid. Which should sound better, as it is or use the 40% tap? In the picture, I have to OLD OPT's sitting on top of the NEW OPT's just for show. The new OPT's are Edcor GXSE15-8-5K. Thanks for replys. |
#2 |
Using the tap will probably give higher output power but also higher distortion than triode mode. If you have sufficient power for your speakers and room then stay with triode mode.
#3 | |
20 |
#5 |
#6 |
20,
I like your style, take it apart and play with it. Are you going to adjust the bias point of the 6V6 while you are at it? DT |
#7 |
If power and distortion are said to be the same for triode and pentode mode then either the datasheet is wrong or you are misreading it. Perhaps they accidentally duplicated a table?
#8 | |
NJ7P Tube Database Search |
#9 |
The numbers are overall gross numbers. They tell nothing about the distribution of harmonics which is more important than the total THD by itself.
#10 |
This 6V6 data sheets shows 1.0W at 5% distortion for triode mode at 250V: http://www.mif.pg.gda.pl/homepages/f...84/6/6V6GT.pdf
6AQ5 should be similar. |
| FS: Radio Shack 40-1354a, 40-1197, 40-1242e | db6546 | Swap Meet | 2 | 26th November 2009 12:11 PM |
| 40% Tap direct to plate | GlidingDutchman | Tubes / Valves | 9 | 12th July 2008 09:15 PM |
| Speaker Rebuild - Radio Shack 40-1271 and 40-1024 | davidallancole | Full Range | 22 | 8th August 2007 01:56 PM |
| AVEL 500VA 40-0-40 Torroidal Transformer FOR SALE | mp006ltk | Swap Meet | 3 | 15th March 2007 09:12 PM |
| WTB: 10,000UF Caps, 1000-1500VA 40-0-40 transformer, Amp Chassis, binding posts, etc. | Spiritzly | Swap Meet | 2 | 25th August 2006 04:07 PM |
| Page generated in 0.20663 seconds (46.14% PHP - 53.86% MySQL) with 11 queries |
