GM70 and Other LTSpice Tube Models - Page 3 - diyAudio
Old 31st August 2012, 10:45 AM   #21
artosalo's Avatar
Thanks Lars
I run this model with my existing amplifying stage and it seems that the
model is quite different than the 6F12P pentode from 1990, the tube type where the heaters can not be seen.
This is my circuit:
In real circuit the voltages and currents are as follows:
Ua = 92 V
Ia = 4,0 mA
Ug2 = 177 V
Ig2 = 0,47 mA
In actual circuit THD is 0,40 % when the output level is 20 Vrms.
In simulation the screen current is much smaller than in real case.
To get the simulation work as the actual circuit works the screen resistor should be some 750 k when in actual circuit it is 220 k.
6C33C tube socket for GM70 tube?? gaborbela Tubes / Valves 9 17th June 2011 05:23 AM
New GM70 tube with problem FullRangeMan Tubes / Valves 9 17th June 2010 12:10 PM
LtSpice - Russian tube models Svein_B Tubes / Valves 11 5th May 2010 02:55 AM
Ltspice and Valve models Melon Head Software Tools 3 18th October 2009 08:35 AM
Need help with tube models in LTSpice Bitrex Tubes / Valves 5 6th August 2009 07:28 PM
Copyright 1999-2017 diyAudio
