| diyAudio Sponsor | ||
I’m not sure I am thinking about this the right way and any help you can offer is appreciated.
For the purposes of finding the feedback voltage applied to the grid of the second stage do I need to consider the output Z of the previous stage to be in parallel with RG? Also, what about the input z of the second stage in this drawing? Is that also in parallel with RG? I am thinking yes for both but... I don’t know. Thanks, Marty |
#2 |
Yes on both.
/Olof
I'm not allowed to do magic, union rules... |
#3 |
Ahhh… thank you, thank you
If I finally have my mind around this..RFB above the parallel impedances forms a frequency dependent voltage divider for the feedback AC. Assuming negative feedback… Vout from the stage on the left should equal the grid swing required for the stage on the right + the applied feedback voltage if the output voltage on the tube on the right is to have Vout closed loop = Vout open loop. Am I on the right track? |
| Current feedback - Voltage feedback, how do I see the difference? | Ouroboros | Solid State | 421 | 28th May 2011 10:06 AM |
| 'Local Feedback and Nonlinearity of Multistage Feedback Amplifiers' | mikeks | Solid State | 62 | 20th July 2005 08:03 AM |
| Trying to understand negative feedback | psysjal | Tubes / Valves | 18 | 24th January 2004 08:25 PM |
| Page generated in 0.13962 seconds (47.07% PHP - 52.93% MySQL) with 11 queries |
