#21 |
I haven't had a chance to breadboard it yet, but simulations show greater distortion with the screen controlled servo amp than the cathode controlled servo amp.
#22 |
I can recommend bring temporary change in diagram.
I imply real device, use oscillograph .I sure in diagram keep error. Alternative draw another diagram, on this diagram insufficiently information . |
#23 | |
jan didden
It is a capital mistake to theorise before one has data. Insensibly one begins to twist facts to suit theories, instead of theories to suit facts - Sherlock Holmes Check out Linear Audio Vol 5! |
#24 |
aeandm, the Zener diode actually works on the breadboard. It keeps VGs near 180V. Max screen voltage is specified as 170 for the 6P41S, and it I allow it to go much higher bias voltage must go much lower.
I do not understand your schematic. Am I supposed to bias the screen at a fixed level with the circuit shown? janneman, I added 33 and eventually got it up to 51Ohms. that helps. tks. |
#25 | |
связано с раскачкой выходного каскада, на транзисторах реализован эл. фильтр, зачем сигнал подан на него(33К) и где минус фиксированого смещения? Поэтому и предложил временно упростить, может я чего-то не знаю? |
#26 | |
Translation: What you probably don't know that I tried to save you from being banned by moderators. Did you read forum rules? I offered you to help, but did not promise to translate each message. If you need help please go to Private Messages and ask me there.
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
#27 | |
предупреждений их можно взять и плавно переместить туда, переведите как учетную запись aeandm можно удалить здесь мне не интересно |
#28 | |
Anatoliy is right, you need to send this to him via PM, and ask him nicely for help as he is probably very busy.. I understand English is not your native language but as he points out you are violating the English language forum policy. (However don't give up perhaps you'll get the hang of the language over time.)
"Extraordinary claims require extraordinary evidence." - Carl Sagan |
#29 |
This has been a rather interesting exercise. So far I've only had time to run simulations and it will probably be the weekend before I can get my tubelab back on the bench to verify the results.
Both circuits produce the same results (or so close as to be the same) given that the anode current and grid to cathode voltage are the same and the screen voltage is adjusted to produce the same cathode current. The input voltage is nearly the same to produce the same output voltage under these conditions. Unfortunately both produce fairly high distortion (25%) at 1W, 2.8Vrms into 8 ohms. |
#30 | |
| LTSpice, Closed loop gain? | Neutrality | Software Tools | 8 | 17th August 2011 08:16 PM |
| Lower closed loop gain? Higher slew rate. | fotios | Solid State | 4 | 27th July 2009 01:41 AM |
| Hump in Closed Loop Frequency Response -- Root Cause ? | EUVL | Pass Labs | 22 | 12th January 2007 01:20 PM |
| hum,ground loop,earth loop problem with your answers please | frank2395 | Pass Labs | 2 | 17th May 2005 06:46 PM |
| Opamp phase shift - open and closed loop. | Circlotron | Analogue Source | 8 | 23rd April 2003 07:06 AM |
