Closed loop stability help needed.
Old 14th November 2011, 06:44 PM   #11
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Or remove C10 and shift 2 remaining poles further from each other.
But still, I don't see bias supply for NPN transistor base and output tube.
The Devil is not so terrible as his math model is!
Old 14th November 2011, 06:51 PM   #12
jerluwoo is offline jerluwoo  United States
jerluwoo's Avatar
Q1 is PNP and bias is supplied from the cathode of 6J9 being more negative than ground.
Maybe using a zener instead of R5 may help things as well.
Old 14th November 2011, 07:11 PM   #13
aeandm is offline aeandm  Ukraine
Hello, I recommend disconnected chain create loop,
and give signal 1000Hz input (P=.indifferently ). Chain creator instability is error diagram .
Bias 6P41C is -regulation, temporarily .
aeandm
Old 14th November 2011, 07:22 PM   #14
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Good ideas.
The oscillations are caused by the control loop - it's loop gain is set by the input cap, and the input source can be seen as a (low) impedance in series with the cap. The loop gain is directly proportional to that series impedance. Make C1 larger, that decreases the series impedance and that decreases the loop gain - no more oscillations. Classical.
The current position of C10 causes a lot of phase shift in the loop, exarbating the problem.
The above advice is a good start. Note that the control loop basically only needs to be a DC or very low speed loop.
You can also bang it with lots of cap at the C10 position, like 100uF or more. That'll teach it
jan
Music is dither to the brain; lets me think below the usual chaos - me
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
Old 14th November 2011, 07:59 PM   #15
Wavebourn's Avatar
Sorry, my typo. Of course, I meant PNP. But on schematic I did not see any resistor from base to cathode, only to the anode of the preamp tube.
Anyway, 3 poles is a bit too much. I would use 2 of them with shifted from each other time constants.
Old 14th November 2011, 08:28 PM   #16
TheGimp is offline TheGimp  United States
TheGimp's Avatar
The goal of the circuit is to allow me to direct couple the Mu stage output to the 6P41S.
My chain of thought was that since it is direct coupled, I can use the Mu stage to set the bias.
With the triode biased by an LED and it's anode feed from a current source it behaves like a voltage source, and it thus should be possible to control the voltage at the cathode to shift the bias to the 6P41S.
So, use the bias voltage at the 6P41S to close the loop and make it a servo.
It looks like my best approach might be to remove C10 and increase C4 to say 2200uF?
If I remove C4 and C10, what would be a good starting value for connecting from Q1b-c?
Old 14th November 2011, 09:28 PM   #17
Dear diyAudio
Sorry , I slowly translate english. For me is simpler
draw diagram, now I work out a problem. I think R8
to e. Q2, and b.Q1 through additional resistor e.Q2.
R8=60mA 6P41C,additional resistor =? (-U=?)
Remove VD1 and C9 is not line element.
aeandm
Old 14th November 2011, 09:28 PM   #18
Wavebourn's Avatar
I would simplify your servo a lot, you don't need so huge OL gain; on low frequencies servo adds own distortions and instability.
Try one NPN transistor, emitter on ground, collector to screen grid of dynamic load, resistive divider from cathode of an output tube shunted by a cap to it's base.
Old 15th November 2011, 03:24 AM   #19
TheGimp's Avatar
Something like this Anatoliy?
Certainly more elegant with fewer poles/zeros.
Old 15th November 2011, 05:20 AM   #20
Wavebourn's Avatar
Yes, something like this. But base current needs to be limited...
Closed loop stability help needed.Hide this!Advertise here!
LTSpice, Closed loop gain? Neutrality Software Tools 8 17th August 2011 08:16 PM
Lower closed loop gain? Higher slew rate. fotios Solid State 4 27th July 2009 01:41 AM
Hump in Closed Loop Frequency Response -- Root Cause ? EUVL Pass Labs 22 12th January 2007 01:20 PM
hum,ground loop,earth loop problem with your answers please frank2395 Pass Labs 2 17th May 2005 06:46 PM
Opamp phase shift - open and closed loop. Circlotron Analogue Source 8 23rd April 2003 07:06 AM
Copyright ©1999-2017 diyAudio
