diyAudio Sponsor
Old 12th November 2011, 08:44 PM   #1
Default Installing Hammond 1609s in K12-G
Hi, this is my K12G amp. The case is made from a WW2 artillery shell box. I have been upgrading it recently. Mods include New coupling caps, removed blocking caps, filament snubbers, hv snubber and uf diode. I've got some hammond 1609 transformers that I would like to install now, but I am having trouble with the primary side.
The original output has a B+ and two other wires, the hammond has a B+ and four, here is some info
Hammond Mfg. - "Classic" Push-Pull - Tube Output Transformers - (1608 - 1620, 1645 & 1650 Series)
http://diyaudioprojects.com/Gallery/...ge.php?pid=368
Old 12th November 2011, 09:10 PM   #2
I think I deleted my first post? Anyways I built a K12g amp. The case is a WW2 artilery shell box. I am in ht eprocess of upgrading it. The Mods I have done include new coupling caps, removed blocking caps, Hv snubber, filament snubbers and uf diode. I have some hammond 1609s i would like to install but I am having problems with the primary side.
The original transformer has a b+ and two other leads and the hammond has a b+ and four
S-5 Electronics K-12G Tube Amplifier Schematic - DIY Audio Projects Photo Gallery
Old 12th November 2011, 09:35 PM   #3
The blue/yellow and the brown/yellow are not used in your case. Tape the end of these wires and tie them out of the way
Old 12th November 2011, 09:43 PM   #4
rmyauck is offline rmyauck  Canada
Those extra wires Bruce mentioned to tape up/ insulate are for UL (Ultralinear) use if you choose to use that mode later on.
Old 12th November 2011, 09:47 PM   #5
Yes, you are correct. You could convert your amp to ultralinear later if you want to compair the two modes.
Old 12th November 2011, 09:53 PM   #6
UL can help with woofer low end bass control. Probably worth a try down the road as many like it. Probably depends on the speakers used for how you like it.
I kinda sorta burned up my K12-G power transformer RevMen Tubes / Valves 21 7th October 2011 09:42 PM
K12-G tube amp problem JTCamp Tubes / Valves 14 23rd June 2011 09:01 PM
FE206En & Karlsonette (1st K12) freddi Full Range 2 11th April 2010 10:41 PM
Phonic Powerpod k12 Schems? ProMusic Solid State 0 4th July 2008 10:49 PM
Building the Karlson K12 Need advice fin1bxn Multi-Way 0 29th January 2007 02:30 PM
Page generated in 0.19697 seconds (32.35% PHP - 67.65% MySQL) with 11 queries
