diyAudio Sponsor
Old 11th November 2011, 10:07 PM   #1
lazzer408's Avatar
Default Mini amp questions
I'm back into tinkering with tubes again now that the cold weather is here.
I found this schematic online and had a question about the output stage. It lacks a dedicated phase inverter and I don't see why this method of phase inversion was chosen over the option shown in the second image. Can someone explain? Any advantage to the design in the second photo?
Old 12th November 2011, 02:13 AM   #2
One less triode needed.
Old 12th November 2011, 02:28 AM   #3
lazzer408's Avatar
How so? There's 3 in both drawings.
Old 12th November 2011, 02:49 AM   #4
Miles Prower's Avatar
That first design is a self splitting LTP/PA in one. This particular implementation is horrible. A 440R resistor isn't nearly enough tail load, and a CCS would be a helluvalot better (though it'll require a negative rail). It also enforces Class A operation, since the limit of plate current swing will be between 0mA and Itail.
It will probably perform better than a cathodyne if your DC rail voltage is limited. (In that case, you could always substitute a MOSFET for a triode and use that for your cathodyne (sourceodyne?) splitter instead.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 12th November 2011, 02:53 AM   #5
tubelab.com's Avatar
The phase splitter (first triode) in the first schematic has zero gain. The gain stage in the second schematic has a good deal of gain but the output tubes have less gain since they operate as an LTP with a shorter than usual tail. There are trade offs in both cases and the self split version (second schematic) will have a somewhat lower total power output and imperfect balance. This will cause it to sound somewhat like an SE amp, but allow the use of a P-P OPT.
I explored many versions of this circuit and settled on something quite like this for the 2 watt guitar amp in the Hundred Buck Amp Challenge thread. The schematic is in post # 1021.
The Hundred-Buck Amp Challenge
I now have a version using a mosfet phase splitter that can be disabled allowing the 2 watt "quasi SE sound" and 5 watts of full P-P pentode terror.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 12th November 2011, 03:45 AM   #6
lazzer408's Avatar
I thought the 2nd pic IS a cathodyne PI.
The first tube in the first drawing isnt a phase splitter. It's just a gain stage. Shouldn't a plate follower have some gain?
The second stage doesn't have a gain stage. It's just a cathodyne phase inverter (from what I understand).
I'm wondering why that designer chose to build the output stages the way he did. My thought was he could have made better use of that first triode as a PI. If he required it for gain, he would have been better off paralleling the triodes of V3 and wiring it for SE to keep his first triode gain stage.
Old 12th November 2011, 08:19 AM   #7
Svein_B is offline Svein_B  Norway
The "Compact Amp" with the self splitting output tubes was published in Electronics World, June 1961: Compact Hi-Fi Power Amplifier by Melvin Leibowitz
As pointed out above, it is not a great concept. It has been elaborated in a number of steps published at: Simple EL84 poweramp/integrated
SB.
Old 12th November 2011, 01:23 PM   #8
You are right. The schematics arent visible while posting a reply and my brain goes fuzzy at 11PM, that's why I turn the bench power off at 10PM to avoid shocking moments. I got the schematics reversed in my post of last night.
The bottom schematic is a conventional design and the first stage phase splitter has no gain. The unbypassed cathodes in the output stages will cause a mild gain drop as long as the tubes remain in class A and a rather serious gain drop if driven into AB teritory. The output impedance increases in both cases. Add a cap if you need more gain.
The top schematic is a self split output stage that acts as a rather imperfect LTP. The input stage does indeed have gain. The major advantage here is a low parts count, since it doesn't do anything real well. It does allow the use of an ungapped P-P OPT in a circuit that provides a somewhat SE like sound. I am exploiting this property in a guitar amp that has $40 in total parts count. The extra output tube costs $1. The difference between a SE and a P-P OPT is $7. The design works but I can't get the THD below 2% at any power level and it rises with power output. It's good for a guitar amp, but I wouldn't try it for HiFi.
Old 12th November 2011, 02:43 PM   #9
Merlinb is offline Merlinb  United Kingdom
Because it's a guitar amp. Not a hifi amp.
The whole point of this amp was to get very low output volume (power), and lots of gain. A 'proper' PI would sacrifice gain but result in more output volume than necessary, the exact opposite of the design intention.
Here's the full schem for the benefit of everyone. Notice how it's totally anti-fidelity...?
Old 12th November 2011, 03:15 PM   #10
Frank Berry's Avatar
Why not build a SE amp?
Your schematic will not give true push-pull operation. There will be much more 'push' than 'pull' which will severely limit the available output power (and increase the distortion).
Since you don't require a whole lot of power, it would seem that a SE design might be a better and less costly solution.
Frank
Mini-A PCB finished... Some questions on it ;) Xandrell Pass Labs 26 15th April 2011 03:10 PM
mini aleph build questions mr.duck Pass Labs 33 11th May 2009 05:00 PM
Mini Aleph Questions audioboy Pass Labs 6 3rd September 2007 03:02 PM
JGs Mini Monitor - additional questions Benny the 2. Multi-Way 9 13th May 2005 12:27 PM
Page generated in 0.17409 seconds (71.49% PHP - 28.51% MySQL) with 11 queries
