2A3 to 45 Cathode Wattage?
Old 8th November 2011, 10:11 PM   #1
batsong is offline batsong  United States
Default 2A3 to 45 Cathode Wattage?
Thinking about switching from 2A3 to 45. Have a few questions:
Would you simply add another cathode resistor in parallel (eg. another 750R)? Or replace the existing 750R with a single resistor (1K5)?
Is a 20W rating necessary for the cathode resistor?
A switch enabling one to change 2A3s to 45s 'on the fly'?
Any help will be appreciated. Thanks.
-Gabe
Old 8th November 2011, 10:22 PM   #2
boywonder is offline boywonder  United States
boywonder's Avatar
Assuming that you want less current, do you mean "in series"?.......paralleling a pair of 750R resistors gives you 375R...
Old 8th November 2011, 10:42 PM   #3
Thanks. Meant series.
Old 9th November 2011, 01:30 AM   #4
Sorry about that. I have been juggling PS capacitor values for this amp. Trying to decide whether to implement Ultrapath or W.E. and substituting quality film for electrolytics, while trying to save space and expense.
Old 9th November 2011, 04:19 PM   #5
boywonder's Avatar
Default I'm no expert but......
Since nobody has jumped in here........
Assuming SE operation and looking at Duncan Amps TDSL data, it appears that both tubes like about 250V on their anodes, and the 2A3 needs a 750R cathode R to keep the grid at -45V for 60ma idle. The 45 needs a 1500R cathode R to keep the grid at -50V for 36ma idle.
TDSL Tube data [45]
TDSL Tube data [2A3]
IIRC, the 2A3 is essentially a doubled up 45 so the above makes sense (to me anyway)
Using ohms law, for 2A3 P=(Isquared)(R) so .06 x .06 x 750=2.7W and for 45 P=2W. I would use at least a 5W R....
I suppose that you could have a switch to swap tubes, just be careful or you will fry the 45's on the 2A3 setting!
Also, according to the TDSL data, the heater current of the 2A3 is 2.5A and the 45 is 1.5A, so your filament voltage may be high when running the 45's.
Old 9th November 2011, 07:24 PM   #6
Thank you for all of the work. Very informative.
Filament voltage measures 2.7V.
2A3 to 45 Cathode Wattage?Hide this!Advertise here!
6C6-2A3 Amplifier: Changes for 45? Jon the Grimm Tubes / Valves 1 3rd December 2010 08:53 AM
Simple 45/2A3 schematic error? Richard Ellis Tubes / Valves 1 14th April 2008 03:24 AM
Tube designs: 45 driving 45/2a3/300b? Veniogenesis Tubes / Valves 4 23rd April 2007 06:59 PM
WTB: OPTs for 2A3 or 45 SE; 240 v power tranny for 2A3 or 45 rick57 Swap Meet 0 8th November 2006 01:07 AM
Seeking help about my 2A3 to 45 conversion arnoldc Tubes / Valves 14 14th June 2003 02:05 AM
