When using a DC filament supply on a DHT... - Page 4 - diyAudio
Old 17th September 2003, 10:33 PM   #31
That's a good idea. I was reading through some other stuff and realized that I could have bent a pot's terminal to touch the chassis, or something like that - that could probably cause this too.
Old 18th September 2003, 05:03 AM   #32
Well, I think it was mostly my CD-ROM drive. The darn switching power supply in that turned its analog output into a picket fence, and I guess one of my channels is more sensitive to that high frequency noise. I put my older CD player back in, and everything's happy. I did re-flow all solder joints on that input tube just for good measure. Also added the bypass caps for the regulator ICs. Things seem better now. I also re-did the grounding inside the amp, moving the chassis connection to the front of the amp near the inputs. That reduced the amount of HF hash in the output significantly.
So now I need to find an inexpensive CD player/transport that has a digital output (mine doesn't), and doesn't produce picket fences on its output.
K-502 Filament supply (or K-12M) jmillerdoc Tubes / Valves 6 18th November 2009 12:59 AM
Yet another DHT filament supply astouffer Tubes / Valves 25 5th July 2009 11:08 PM
Parallel vs. series filament supply - or another filament idea engels Tubes / Valves 11 13th May 2007 01:06 PM
LV Filament supply quandry selfwilly Tubes / Valves 6 8th July 2006 07:10 PM
DC filament supply LC or CL TBM Tubes / Valves 1 7th August 2005 07:26 PM
Copyright 1999-2017 diyAudio
