diyAudio Sponsor
Old 6th November 2011, 01:58 PM   #1
Default Quad II Switch Mode PSU
Hi, Another Quad II with a mains transformer shorted HT. I have previously tried rewinding, but without much success (i got bored counting the turns and getting the tar off). So as I was just repairing a a modern 300 watt Wharfedale with a SMPs when it occured to me that it shouldnt be too difficult to build a 360vdc and 6.3v(dc) smp inside the existing Quad transformer can. So I have reserched the forums and cannot find anything directly relating to this, I realise that there are a lot of problems with the noise from the smp and the ht coming on too soon which would need resolving.
So has anyone done this?
Old 6th November 2011, 02:54 PM   #2
It sounds perfectly feasible. You could overcome the instant HT problem by leaving the existing GZ32 in place and feeding the SMPS supply to both anodes. You would then need to supply 5 volts as well.
Switch mode PSU argonrepublic Power Supplies 2 18th October 2009 10:08 PM
Switch-mode PSU for tube heaters? deltavektor Tubes / Valves 9 31st October 2008 08:07 AM
Using a spdt switch to select between triode mode and pentode mode on a guitar amp. G Tubes / Valves 19 15th March 2006 09:15 AM
Standby switch for Quad II? Zombie Tubes / Valves 13 13th March 2003 11:20 AM
Troublesome Switch mode PSU stigla Solid State 9 23rd June 2002 12:28 PM
Page generated in 0.07660 seconds (73.47% PHP - 26.53% MySQL) with 10 queries
