diyAudio Sponsor
Old 5th November 2011, 11:22 PM   #1
Trileru is offline Trileru  Romania
Default global negative feedback in el84 push pull
Hello all.
I am trying to apply global negative feedback as described in the Bevois Alley amp by Morgan Jones and I can't figure out the Rl of the input stage and Rl of the concertina. How do I calculate each?
Another question is in the formula needed to find rk :
rk=(Rl+ra)/u+1 ... that u is the gain coefficient of the tube or the actual gain measured at one of the outputs of the concertina? The 6n1p-ev dictates a u of 35 while I measured 24.8 in my amp. Witch one should I use?
My soundcard outputs 1.2V measured at full volume. What is the full voltage needed for 12.5W output? So I can adjust the gain of the amp accordingly.
Old 6th November 2011, 12:15 AM   #2
here is my current setup
Old 6th November 2011, 10:46 AM   #3
SY's Avatar
That rk is the "looking in" impedance at the cathode. For the purposes of feedback calculations, it's effectively in parallel with the cathode resistor. The u is the mu of the tube.
By Rl, do you mean the plate load resistors? Those are derived by playing with load lines on the tube's plate curves.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 7th November 2011, 06:18 AM   #4
The open loop gain of the schematic you showed is some 43 ( 32,7 dB)
assuming you have typical 8k to 8 ohm output transformer.
With 5k6 feedback resistor from the secondary to the cathode of 6N1P the GNFB is 11 dB and total gain is 21,7 dB (A=12.2). Thus the 12.5 W output (10 Vrms) requires some 0.82 Vrms input level. Feedback resistor should have small 47...100pF capacitor in parallel depending on the OPT you use.
New EL84 Push-Pull Monoblock Kashmire Tubes / Valves 7 14th January 2011 12:10 AM
global negative feedback schematic sdinfo Tubes / Valves 160 26th August 2010 07:16 PM
EL84 push pull slideman82 Tubes / Valves 4 19th June 2009 03:40 PM
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 3rd November 2005 11:25 PM
Global Feedback in Push Pull Amps gingertube Tubes / Valves 14 17th May 2005 04:22 PM
Page generated in 0.07739 seconds (68.20% PHP - 31.80% MySQL) with 11 queries
