| diyAudio Sponsor | ||
Hello,
I haven't been able to find anything by searching the archives or googling, I'm very much a beginner - just after an opinion on a PI circuit I threw together... have mercy... I'm attempting to put a solid state phase inverter to feed a low power valve output stage. I'm using low voltage rails, 110V before rectification (130 after?), as I have a trafo that will do that. Ive used IRF840 mosfets because I have some, I'm not sure if MOSFETs are the right choice...? I'm using LTP, because its a circuit I think i know. ![]() I havent just swapped the fet in as the Vak isnt same as Vgs(on), I tried to bais properly. But I'm not sure, have I done it right? Thanks in advance. |
#2 |
IRF840 is an enhancement mode FET, so it needs positive gate bias to turn it on. You have given it negative bias, like a valve or depletion mode FET.
As it is an 8A power FET, I'm not sure how well it will work with only 1mA drain current. |
#3 |
Thanks for your reply DF96, could you recommend a better device that will be happy with the voltages/currents involved?
sorry for my stupidity, thinking about it, I was treating it as a JFET so I was bound to **** up. I havent ever designed with mosfets before. Is this the correct form for an enhancement mosfet (ignore the values)?
#4 |
#5 |
Ignoring the component values, yes this is nearer the mark. Not something I have tried, so maybe others can help?
#6 |
What's R14 and 15 about? To me the common "tail" should be as "long" as possible. A CCS would be preferable and since you are into ss already, easily implemented.
/Olof
I'm not allowed to do magic, union rules... |
#7 |
#8 | |
A Valve!
Das Beste Oder Nichts |
#9 | |
As far as I remember IRF840 has very high input capacitance. |
#10 |
| Gain of Phase Inverter | hpupo | Tubes / Valves | 10 | 28th May 2011 02:21 PM |
| Phase inverter | ThSpeakerDude88 | Tubes / Valves | 37 | 29th August 2007 03:15 PM |
| 6C8G phase inverter | engels | Tubes / Valves | 4 | 4th February 2007 06:01 PM |
| What is the purpose of phase inverter? | RemoGaggi | Digital Source | 3 | 6th December 2006 05:09 PM |
| Mystery (to me) phase inverter? | porkchop61 | Tubes / Valves | 17 | 6th October 2004 11:16 AM |
| Page generated in 0.10589 seconds (75.80% PHP - 24.20% MySQL) with 11 queries |
