| diyAudio Sponsor | ||
Hi. I have a Core Audio (or VALAB?) buffer that uses 6BC4's. I replaced the fixed input attenuator with a 50K pot. I have two odd things happening:
1) With the pot at minimum (0 ohms), there is audible noise from the right channel speaker, almost like an oscillation. 2) As I increase the pot to max, a DC offset appears at the right channel output (1.2V at max - enough to trigger the DC detect in my DC coupled ARCAM amp). This offset is only present with an input signal playing (1KHz from a PC). Since adding the pot, I also replaced the valves and replaced the output coupling caps - these were 10uF film caps connected across large bipolar electrolytics. They are now just 22uF polyprops (Mcaps - nothing too exotic). The only items after the caps are a resistor with back to back zener diodes across it and a muting relay. Its annoying as I would like to use the DC coupled inputs of the amp. Any ideas appreciated, Paul |
| T106-2 core vs.??? core Amplifier problem | zox2003 | Class D | 21 | 18th March 2011 10:36 PM |
| J Fet Buffer problem - help ! | AndrewGM | Solid State | 6 | 22nd October 2009 10:14 PM |
| problem with 12AE6A buffer | ionomolo | Tubes / Valves | 2 | 29th March 2009 11:40 PM |
| Selecting audio tranny core size | ashok | Tubes / Valves | 16 | 2nd April 2005 07:49 AM |
| Any website reference for diy choke ,siliver R-core, C-core, EI and power transformer | bmpa | Parts | 2 | 22nd April 2004 04:15 AM |
| Page generated in 0.06181 seconds (65.84% PHP - 34.16% MySQL) with 10 queries |
