diyAudio Sponsor
Old 8th September 2003, 09:33 PM   #1
G is offline G  United States
G's Avatar
Default Help with lowering filament winding voltage.
Hi All,
I've got a Hammond 372JX to use with my SE EL34 amp but Steve (Positron) was kind enough to point out that I may have problems because the filament winding is rated for 8 amps and the filaments in my amp will only put a 3.9 amp load on it. I would like to keep the voltage at about 6.1 volts or so to prolong the life of the heaters of my 5687's (they are getting more costly everyday). How would I go about figuring out how much resistance to use to lower the voltage or at least keep it at 6.3 volts? 6.3 volts at 8 amps means the winding is capable of 50.4 watts of power at full load. I will be putting about 25 watts to use. So do I need to use a high power resistor to dissipate the other 25 watts to get 6.3 volts on my heaters? I know this sounds simple but I can't seem to figure out how to figure this out. Any help on this would be greatly appreciated.
Gavin
Old 8th September 2003, 09:53 PM   #2
diyAudio Senior Member
fdegrove's Avatar
Gavin,
It's not because something is capable of delivering more than what you actually load it with that it's going to push this through the load.
What Steve meant is that the efficiency is higher with the more powerful xformer giving you excess voltage.
Just use Ohm't law to calculate the value and wattage of your dropping resistor or use a regulator and you're done.
Frank
Old 8th September 2003, 09:55 PM   #3
I had a similar problem, and added resistrs to my filament wiring to bring the voltage down. If you want to get really accurate, you'll have to build your amp and measure exactly how much voltage you're seeing across the filaments, and then you'll know what resistor values to use. You could guess by figuring out your transformer's regulation, but that was too much math for me.
Here's more or less how I figured this out. Your tube's ratings chart says it takes 900mA @ 6.3V, so when the filament is hot, it has about 7 ohms resistance (R = V/I = 6.3 / .9). Now, let's say you build your amp and you find that you're getting 6.5V across the filaments. Your target is 6.1, so you need to drop 6.5 - 6.1 = 0.4V across the resistor. You have 900mA flowing through this circuit, so your resistor is (again using R = V / I) .4 / .9 = 0.4 ohms. You can use series/parallel combinations of resistors to get to this value if you want. What I did was to use 1/2 the resistor value, and put 2 resistors in both legs of the filament circuit. Something like this:
Code:
Transformer                 R
-----3||E----------------/\/\/\/\------------------|
     3||E                                          |
     3||E                                          |
     3||E                                           \
     3||E                                            > Filament
     3||E                                           /
     3||E                                          |
     3||E                                          |
                            R
So, in this case, each R would need to be 0.2 ohms. Obviously, when you set your amp up you won't get 6.5V, but the calculation will be the same, just start with whatever voltage you measure.
And yes, watch the power rating. For this example, each resistor is dissipating (I^2*R) = .9*.9*.2 = 0.162W, I would use a 1/2W or 1W resistor here.
Hope that helps.
Saurav
Old 8th September 2003, 09:59 PM   #4
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Gavin,
rather than a big 25 watt resisitor burning up heat, why not go for a series resistor for each valve.
To calculate the series value required, you need the measured voltage (actually at the valve pins), the desired voltage, and the heater current of the valve in question.
For operation at non-standard voltages eg 6.1v, there will be a small inacuracy in the calculation due to the temperature cooefficient of the heater. But it's fudgeable.
Edit: I wrote this a while ago. Since then others have posted.
Old 8th September 2003, 10:03 PM   #5
fdegrove's Avatar
A side effect of using the resistors on the secondary side of the xformer is that they reduce inrush current...which in turn extends tubelife...
Frank
Old 8th September 2003, 10:08 PM   #6
And putting a resistor in each leg reduces common mode noise.
Actually, I don't know if it does, but I impress myself when I say things like that
Old 8th September 2003, 10:32 PM   #7
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
It does if you add a 10n capacitor from each heater pin directly to the chassis because you have then made an RC filter.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 8th September 2003, 11:36 PM   #8
G's Avatar
Thank you all very much. For some reason I thought the answer I was getting with the equation R = E / I was wrong because of the limited power ability of the winding. I guess what I'm saying is that just using R = E / I puts no limit on P theoretically. In this instance though there is a limit as to the power the winding can supply. Even so, I now see that P is meaningless in this context except for the power rating of the resistor I use. Thank you for all of the help.
Gavin
Raising filament winding above cathode with a EZ81 in the circuit OK? G Tubes / Valves 3 15th May 2008 08:29 PM
lowering AC heater voltage help? sbelyo Tubes / Valves 9 14th April 2008 01:28 AM
Taking a Hammond 369BX filament winding to the limit? G Tubes / Valves 3 15th January 2008 04:25 PM
Grounding the Filament Winding alexmoose Tubes / Valves 14 8th June 2006 03:39 PM
lowering the voltage Lowjacker Power Supplies 7 11th March 2006 09:11 AM
Page generated in 0.09695 seconds (77.44% PHP - 22.56% MySQL) with 10 queries
