| diyAudio Sponsor | ||
Hi, newbie here, please bare with me....
I wanted to experience (to a degree) some tube based equipment and a quick look in eBay show dozens of sub 100 Eur preamps/buffers etc. Is anything worthwhile looking and trying to start getting a feeling of the "tube" sound? |
#2 |
There may be, but I haven't seen one yet. We get folks who buy these cheap kits (usually of China origin) posting quite often to see how they can fix them. A combination of poor thermal management, bad layout, counterfeit parts, and attempts to run high voltage tubes at low voltages seems to be common themes.
A good tube buffer won't have any "sound." Most of the cheap buffers, perhaps in order to get a "sound," or perhaps out of sheer incompetence on the part of the (I use the term loosely) designer, have notably high distortion.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 |
In a word no.
Check out the Aikido line stage. |
#4 |
#5 |
If a valve amplifier is working correctly then apart from heating up the room you should not "experience" it at all. You just hear the music. (Actually, its the same for a correctly working solid state amp too). Its the ones which are not working properly which you "experience", although some people seem to prefer this.
#6 | |
#7 |
Aikido Line Stage Amplifier Kits & More FBFF Hybrid Regulators
I think you will experience the clarity that glass has over sand. |
#8 | |
OK, I'll put that on my wish list, thanks. |
#9 |
The point of a tube buffer is to offer a high impedence to the source and a low impedence to the load. This will remove some of the load from the output stage of the source and drive the input of the load better. My experience of the Musical Fidelity X10D was that this improved detail, but didn't introduce a valve sound to the mix.
My experience of well designed valve equipment is that they do not have a valve sound (ie mushy) but have a slightly smoother delivery with no loss of detail. A good valve amp sounds like a good amp. Hope that helps. Shoog |
#10 |
Shoog, thanks for you input!
| Cheap ($235) SE Tube amp kit, transformer and chassis on ebay | aspringv | Tubes / Valves | 68 | 11th January 2012 03:00 PM |
| Tube Phono Preamp PCB Ebay? are these any good | fortytwo | Tubes / Valves | 12 | 7th July 2009 01:47 AM |
| Can you get a *good* cheap tube amp in HK? | rick57 | Parts | 0 | 12th April 2005 04:10 AM |
| Preamp Input Selector & Buffers | Devil_H@ck | Chip Amps | 9 | 2nd May 2004 10:29 AM |
| Page generated in 0.09655 seconds (78.98% PHP - 21.02% MySQL) with 10 queries |
