diyAudio Sponsor
Old 2nd November 2011, 03:21 PM   #1
rongon is offline rongon  United States
Default 10k and 6k primary windings on OPT. Use for UL?
One of the nicer pieces I've collected is a pair of UTC LS-63 OPTs, which have 10k and 6k primary windings. (3.75, 7.5, 15 and 500 ohm secondary windings.)
Since Ultralinear config often calls for 40% taps on the primary, I was wondering... Do those 6k taps on my LS-63's represent 60% taps or 40% taps?
I have a feeling that a 40% tap would be 40% of winding common to plate and screen, and so the remaining 60% to the plate alone, but would like confirmation on this.
Thanks...
Old 2nd November 2011, 04:21 PM   #2
DF96 is offline DF96  England
A 6k tap on a 10k winding is at 77.5%, so almost triode mode. I guess you could turn it round and have 22.5% tap instead. As a general rule, UL works best with transformers designed for UL as the requirements for tight coupling and inter-section stray capacitance are more demanding than a normal OPT.
Try it, but don't be surprised if it has HF instability.
Old 2nd November 2011, 04:28 PM   #3
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Np/Ns=SQRT (Zp/Zs)
SQRT (6000/10000) =77.4%
Old 2nd November 2011, 05:53 PM   #4
OK, hmmm... I see. Thanks.
6K:8 25W SE OPT, now what tube should I use? dnewma04 Tubes / Valves 6 6th February 2008 02:13 PM
Multiple primary windings KimBOlesen Tubes / Valves 2 23rd July 2007 08:58 AM
transformer primary windings Q AndrewT Power Supplies 6 28th October 2006 11:51 AM
cap btween primary and secondary windings? sam9 Power Supplies 8 19th May 2005 06:34 PM
opt windings, need some help jazz Tubes / Valves 13 7th November 2003 02:50 PM
Page generated in 0.06104 seconds (75.02% PHP - 24.98% MySQL) with 10 queries
