| diyAudio Sponsor | ||
I have some EZ80 and PL509 tubes. What is the correct settings for my Hickok 539C tester? Unfortunately the PL509 settings missing, EZ80 found in my datasheet, but not working. I used for my EZ80 the following settings: Fil. Selectorts Bias Shunt Press Range 6.3 EV-0703-1 0.0 80 P3 G - Plate No.1 6.3 EV-0703-7 0.0 80 P3 G - Plate No.2 Anyone can help me? Thank You |
#2 |
A PL509 can be tested as a 40KG6 which is very similar. From the Foreign supplementary data the settings are:
35v EV-1039-2, 27 bias, P4, D range, 2600 min mut cond (plate cap) Your settings for the EZ80 seem ok, except my book says EV-0107-7 for plate 2. (could be a typo? maybe try it)
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University Last edited by HollowState; 3rd November 2011 at 01:15 AM. |
#3 | |
Dear HollowState,
Thank you your answer. I can tested my PL509 tubes. EZ80 settings good, jus I mixed the setting lines. Next time keep my eyes on the lines :-) Do you have 539C too? My 539C is new for me and I have some question. Regads, Krisztian Quote:
#4 | |
Yes I do have a Hickok 539C tester. Victor
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
#5 |
| EICO 666 tube tester - What settings do you use? | rotofluid | Tubes / Valves | 4 | 1st August 2009 01:15 AM |
| Looking to "Borrow" an Amplitrex, 539C or other High-End Tube Tester in SE PA Area | baileyler | Swap Meet | 0 | 14th January 2009 02:07 PM |
| Tube tester settings? | jaymanaa | Tubes / Valves | 2 | 16th August 2006 01:58 AM |
| EZ80 tubes | WALTER BURKHARD | Swap Meet | 3 | 4th July 2003 07:24 PM |
| settings for 300b tubes on 539c tester | TubeHound | Parts | 1 | 19th October 2002 11:44 AM |
| Page generated in 0.08347 seconds (75.49% PHP - 24.51% MySQL) with 10 queries |
