diyAudio Sponsor
Old 1st November 2011, 04:40 PM   #1
Default Neon Lamp Question
Hello,
I have a question about adding a neon lamp as a power indictor between the mains and power transformer on a tube amp. If I do this will it induce hum or noise or cause other problems with the system? The line voltage is 125 and the Neon is rated at 125v.
Thanks,
Old 1st November 2011, 05:23 PM   #2
HollowState's Avatar
Assuming you're speaking of a packaged neon lamp indicator that has an internal resistor to function on 125 volts, place it across the transformer primary after the power switch. (Between implies a series connection which would be wrong) Just be certian to keep the wiring close to the chassis and away from low level signals like the input connector to avoid inducing hum pickup by these circuits.
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University
Old 1st November 2011, 05:34 PM   #3
M Gregg is offline M Gregg  United Kingdom
M Gregg's Avatar
Originally Posted by avengerman14s View Post
Hello,
Thanks,
I guess the Transformer has no low voltage out, because if it does then why a neon? LED with resistor on low voltage out, if its on AC a use a reverse connected diode across LED and resistor in series with the two? 6V lamp? If its just because you like the neon use correct resistor in series with it across the supply keep it away from input circuits.
M. Gregg
What is the sound of one hand clapping?
Old 1st November 2011, 06:53 PM   #4
Hello,
It's the one piece unit designed to operate at 125v. I prefer the Neon lamp for the amp, goes better with the tubes. Just curious if it would inject noise or other issues by attaching before the transformer.
Thanks,
Old 1st November 2011, 07:10 PM   #5
M Gregg's Avatar
Hello,
Thanks,
You won't notice it inject anything into the Tx. However it will produce RFI ie it is a transmitter of radio type noise that can pick up on your input circuit. So use it but keep it away from any input / pre amp tubes or volume controls.
M. Gregg
Old 1st November 2011, 07:11 PM   #6
Frank Berry's Avatar
The neon won't cause any noise problems when connected to the primary of the power transformer.
Frank
Old 1st November 2011, 08:03 PM   #7
Hello,
Thanks for the input, she gets installed in my ST-70 tonight.
Jim
Neon lamp charger vasko Power Supplies 21 31st July 2011 12:38 PM
Elevam's oversized Neon Lamp for Micro Seiki 5 - where to order tiefbassuebertr Analogue Source 9 15th July 2011 08:40 PM
Wiring SPST Switch with Neon Lamp PhrazeMaster Construction Tips 5 9th January 2011 08:28 PM
Where can I get a neon lamp for Garrard 401? honinbou Analogue Source 12 10th March 2006 06:56 PM
Page generated in 0.09213 seconds (74.58% PHP - 25.42% MySQL) with 10 queries
