diyAudio Sponsor
Old 1st November 2011, 07:55 AM   #1
Default 813 review
HELP REVIEW SCHEMATIC
Old 1st November 2011, 08:05 AM   #2
just another
wintermute's Avatar
Hi Calpoly1998 Welcome to diyAudio. I think that you probably should post in the Tubes forum Tubes / Valves - diyAudio
in fact I have moved it
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Last edited by wintermute; 1st November 2011 at 08:12 AM. Reason: move to tubes forum
Old 1st November 2011, 08:24 AM   #3
Vinylsavor's Avatar
Hi!
Some comments:
The max grid leak resistance for the 813 is 50k Ohm and for the 6HV5A 100kOhm
The 6HV5A will not work well with resistor plate load. I recommend a choke load or transformer coupling
The 6HV5A does not need DC heater, AC will work without hum
Besides that there are some drawing errors in the schematic:
813 is shown as indirectly heated and marked 300B
The 6HV5A doesnot have a screen grid
The rectifier in the bias supply is missing
Best regards
Thomas
http://vinylsavor.blogspot.com/
Old 1st November 2011, 01:04 PM   #4
работник
Rod Coleman's Avatar
The driver looks like normal grid driver, but the 813 ouput is configured as a cascode.... I think the grid and cathode have their connexions swapped.
Old 1st November 2011, 02:33 PM   #5
bear's Avatar
Where's the 813's screen?
Looks like someone took a schematic from someplace and changed the plate voltage value and the bias value.
No way are the cathode and grid connections swapped, you can't connect the grid or the cathode to the plate supply and have it work...
Is this a class project? At "Cal Poly"??
_-_-bear
_-_-bear
http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. --
Old 1st November 2011, 06:34 PM   #6
Default 813 help review
Sorry for my laziness from last night.
Thank you many many people in here.
Here is update 813 schematic.
Old 1st November 2011, 06:54 PM   #7
Vinylsavor's Avatar
Hi!
Connect pin 3 of the 6HV5 to the cathode, not to plate!
You might want to look at the schematic of my 211 amp which uses the 6HV5A as driver:
VinylSavor: Making of a 211 Amplifier, Part 1: Planning
I recommend to run the 6HV5 at a higher voltage and more current. A step down interstage will provide a more reasonable gain and nice low impedance drive to the output tube
Best regards
Thomas
Old 1st November 2011, 09:27 PM   #8
firechief's Avatar
Did you fix the grid bias supply? Somewhere you have to have a diode in there.
"You can keep your insurance baby nothing is guaranteed" -Tom Petty
Old 1st November 2011, 11:05 PM   #9
I fixed grid bias supply circuit and connected Pin 3 to pin 4
Thank you
Old 1st November 2011, 11:27 PM   #10
Default Here is Actual amplifier
with all your help..
i got 25w output with less than 2% dis from (25 to 20K)
Thanks, Rookies
How is this possible? (A hi fi review. Review) terry j Multi-Way 50 5th June 2008 11:46 PM
813 Thoughts Steven-H Tubes / Valves 40 26th January 2008 02:24 AM
Your opinion on 813? Jax Tubes / Valves 5 16th January 2004 09:10 PM
813 valves slowmotion Tubes / Valves 36 27th January 2003 11:54 PM
Page generated in 0.09975 seconds (81.40% PHP - 18.60% MySQL) with 11 queries
