diyAudio Sponsor
Old 1st November 2011, 07:21 AM   #1
Default tube circlotron for headphone amplifier
Hello everybody,
Sure many of you have heard about the circlotron schematic, which is
used in many OTL architectures to ensure a DC free amplifier output
without having the need for a transformer or capacitor coupling
stage.
I wondered whether whether it is possible to use this configuration in
an headphone amplifier (stereo version). The point of my uncomplete
understanding is the following: the typical circlotron circuit requires
2 floating voltage sources and drives a floating load in between the
cathodes of the 2 output tubes. When connection a normal speaker to
this system, I see no problem. In the case of a headphone load, the
twi ground terminal are typically connected together (3 wires on
connector). Hence, the cathodes of one path in each amplifier are connected
together. But there is another point in the system, where the amps
are shorted: the GND of the input signal.
Now the question which arises is: is there any problem in this configuration?
I'm not sure about this, not feeling good about this additional short
of the cathode potenzials.
Best regards and thanks in advance...
Stephan
Old 2nd November 2011, 02:26 PM   #2
nobody interested in this discussion?
Old 2nd November 2011, 02:42 PM   #3
tinitus is offline tinitus  Europe
probably the most 'beaten horse' google
Old 2nd November 2011, 03:36 PM   #4
oshifis is offline oshifis  Hungary
Stefan,
Most headphones have a 4-wire cable, with the negative tied together at the jack connector. In this case you need to replace the connector only.
Old 2nd November 2011, 06:40 PM   #5
oshifis, yes this is clear to me as well. But to have a version, which is more general, the question arose. I'm nearly sure, that it is not possible, but only wanted to have a second opinion.
Old 2nd November 2011, 07:02 PM   #6
ups! my post was wrong, sorry
I obviously thought of OTL
and now also remember reading about 'certain' possible safety issues
Old 2nd November 2011, 07:04 PM   #7
yes, safety may be of concern. I'm just wondering, whether a capacitor coupled output stage (class a operation) is more safe. In deed, I have qualms about having this high voltage on the ear in case of damage.
Old 2nd November 2011, 10:02 PM   #8
atmasphere's Avatar
There are no safety issues.
We make a preamp that has a Circlotron output, is all tube and has enough output power to drive headphones.
In doing so, the preamp does rather well with the 3-wire connection, but there is a big difference in sound quality when the 4-wire connection is used instead- enough to make one wonder why anyone would use the 3-wire connection after going through the effort of building a nice headphone power amp from scratch regardless of the circuit used
So yes, it can be done.
Headphone amplifier with TH100 tube JosM Tubes / Valves 1 1st January 2011 06:44 PM
Tube headphone amplifier. oldjade Tubes / Valves 6 7th July 2010 08:59 PM
headphone amplifier = tube + mosfet sparkle Headphone Systems 25 23rd June 2009 02:52 PM
A Tube Hybrid Headphone Amplifier TzeYang Headphone Systems 5 10th September 2008 11:22 PM
Page generated in 0.08095 seconds (81.31% PHP - 18.69% MySQL) with 10 queries
