diyAudio Sponsor
Old 31st October 2011, 03:21 AM   #1
Default 24V powered 6N11 amplifier, 0.25% distortion, pretty good!
Some days before I started a thread to discuss the possibility of designing a low voltage tube amplifier. Almost all the reply posts said there'll be a big distortion. I decide to get a audio analyzer to make sure how big the distortion will be. Today the VP-7732A arrived, I did a test on my 24V powered 6N11 tube headphone amplifier. To my surprise, the distortion is only 0.25%, pretty good for a tube amp. The schematic is similar like this:
The input signal is 100mVp-p and output is 722mVp-p.
When input signal increase to 200mV, output is 1.4V, distortion increased to 1.5%, still acceptable for tube amp
www.siliconray.com High Quality Audio Enclosures, Amp Kits, Amplifiers, PCB Fab Services
Chat with me
Old 31st October 2011, 09:57 PM   #2
mogliaa is offline mogliaa  United Kingdom
mogliaa's Avatar
Not very much in my view. I measured around 0.03% for an 4P1L or 26 stage with 1vrms input. Then for a 6sn7 driver stage at full output swing (100Vpp) an average of 0.36%. All CCS loaded. That is pretty good for a valve! I don't have a good oscillator or test bench so it's just a reference....
You managed to get a great audio analyser, congrats!
Cheers
Ale
"A mistake is always forgivable, rarely excusable and always unacceptable. " (Robert Fripp)
http://www.bartola.co.uk/valves/
Old 31st October 2011, 11:02 PM   #3
For high supply voltage the distortion is low because the tube works in good linearity. But for low voltage distortions is pretty high even with only 1Vp-p
Chat with me
Old 1st November 2011, 08:16 AM   #4
Cookj is offline Cookj  Belgium
Looks like one of Sijosae's
http://www.headphoneamp.co.kr/bbs/zb...esc=asc&no=249
Old 1st November 2011, 08:30 AM   #5
Nice design, the heater power circuit is interesting.
Chat with me
Old 1st November 2011, 08:46 AM   #6
In fact your design is his first iteration
http://www.headphoneamp.co.kr/bbs/zb...esc=asc&no=247
If you look further down the page you will see links to his other MHAA variations
6N11 tube work at 24V power supply? siliconray Tubes / Valves 16 16th October 2011 02:24 AM
PGP (Pretty Good Poweramp) syn08 Solid State 258 26th February 2008 02:31 AM
24v aikido distortion poolorpond Tubes / Valves 13 17th February 2008 05:52 PM
Page generated in 0.07868 seconds (73.96% PHP - 26.04% MySQL) with 11 queries
