diyAudio Sponsor
Old 31st October 2011, 01:46 AM   #1
dgta is offline dgta  United States
Default SS diode replacements
When replacing a vacuum tube rectifier with SS diodes, how do you accurately reproduce the voltage drop of the vacuum tube? I can't find much data on voltage drop vs current, in my particular case for a 5Y3GT. Datasheet only gives one point, 50V drop @ 125mA.
Anybody have any info on this or do I need to create my own data from testing? Is the drop linear with current?
Old 31st October 2011, 02:12 AM   #2
Try 220R to 400R resistor... 5 to 10W...
Old 31st October 2011, 03:39 AM   #3
Defiant is offline Defiant  United States
Defiant's Avatar
This sheet shows the entire curve for the 5Y3GT. Also, thermionic rectifiers follow the 3/2 power law, so you can calculate the voltage drop from a single data point with acceptable accuracy.
OTOH, the best way to reproduce the voltage drop of a tube rectifier is to use a tube rectifier Click the image to open in full size.
Old 31st October 2011, 05:41 AM   #4
Yes that datasheet does. Thank you.
OTOH, I'm not really thrilled with tube rectifiers in my tube tester
Old 31st October 2011, 07:08 AM   #5
yagoolar's Avatar
Send a message via ICQ to yagoolar Send a message via Skype™ to yagoolar
Use PSUD 2 software to simulate power supply condition.
Old 31st October 2011, 08:31 AM   #6
Defiant's Avatar
What kind of tester? Are they vacuum rectifiers or mercury vapor? The latter types look neat, but they are noisier than any SS diode and don't like having anode voltage applied until they are fully warmed up. I wouldn't even hesitate to replace a merc rectifier with a silicon diode and a 12-14V zener
Old 31st October 2011, 01:05 PM   #7
Hickok 752
One of each. Merc is easy. That's why question about 5Y3
Old 1st November 2011, 08:21 AM   #8
Defiant's Avatar
Hickok 752
Is the replacements of the tube rectifiers a PHOGE mod, or is there actually a good reason for doing so?
Old 1st November 2011, 01:22 PM   #9
Don't know what or who PHOGE is, but yes, there are several good (to me) reasons.
1. I don't like dissipating 25W in a box full of electronics with zero ventilation
2. I don't like waiting for tubes to warm up.
3. I don't like having a consumable device that can't be tested ( only have one tester)
4. I might leave it on for hours and it wastes electricity. Most of it in the heaters.
Oh, wait, I found what PHOGE is:
Pulsed homogeneous orthogonal field gel electrophoresis (PHOGE).
Old 1st November 2011, 02:48 PM   #10
There are some nice pics of the guts of a Weber copper cap here
Close call with a Weber WZ34 - AudioKarma.org Home Audio Stereo Discussion Forums
I'm looking for Sony midrange pair (from high-end ss-g7 / ss-g9) vintnt Swap Meet 2 22nd April 2011 09:23 AM
Diode replacements dognut Parts 0 28th March 2009 11:41 AM
Capacitor & diode replacements dognut Parts 2 20th February 2009 11:59 AM
SS R2904/7000 ring vs SS D2904/71000 dome opinions?? Adam D Multi-Way 0 1st September 2004 10:39 PM
Dx 400 Diode Replacements ??? kristijan-k Parts 0 28th June 2002 10:35 AM
Page generated in 0.11373 seconds (83.70% PHP - 16.30% MySQL) with 10 queries
