diyAudio Sponsor
Old 30th October 2011, 11:20 AM   #1
Default Can't get anything from my new pre-amp
Hello,
I recently bought an ART Tube MP Pre-amp, but being totally new to pre-amps can't get it to work properly. I've tried connecting my Condenser Mic in input1 and having another output into the following via/6.5 & XLR: EQ, Amplifier, Laptop and PC. But I don't even seem to get a signal, just noise, as it doesn't do anything when I make any sound into the microphone or lightly tap it. Phantom Power is on in the Pre-Amp and I also have the option of a 20db gain boost that I've played around with. The mic specifically is a Takstar PCM 6100 Cardoid Condenser. Any help right now would be greatly appreciated thankyou.
MC pre pre amp for shelter 501 MK11 cjcc67 Analogue Source 19 24th May 2010 07:17 PM
Blown amp pre-amp in or HU pre-amp out? scraph Car Audio 5 23rd January 2009 12:58 AM
Pre-pre; phono; pre line ;device discrete (bjt/fet) o op. amplifier GIPIONE Solid State 8 18th December 2005 09:09 PM
Passive pre amp vs powered pre amp fatmarley Solid State 21 21st November 2003 02:01 PM
Page generated in 0.05576 seconds (71.07% PHP - 28.93% MySQL) with 10 queries
