Frank's Pre Still In Vogue?
Old 30th October 2011, 10:44 AM   #11
Burnedfingers is offline Burnedfingers  United States
quote
You guy's are talking phono (MM, MC) preamps or just line stages here?
We are talking line stages. If we were talking MM or MC phono preamps I would have recommended your design of preamp with your multiple power supplies.
From personal experience with the Aikido I don't think that a regulated supply would be of a benefit because of the cancellation of the power supply noise in the Aikido circuit.
With your circuit Frank I could tell a difference just using a shunt VR regulated design. To me this means a difference with a good regulated design in my opinion.
Old 30th October 2011, 11:15 AM   #12
On Hiatus
SY's Avatar
That's the tradeoff- the Aikido has good power supply rejection, but at the expense of more tubes. A more basic circuit will have worse PSR, transferring the complexity to the power supply. Take your choice.
The PSR of the topology Frank uses can be greatly improved, in fact made better than the Aikido, but there's a parts-count penalty for doing so.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 30th October 2011, 01:50 PM   #13
thefragger is offline thefragger  Canada
You can't just stop at that... how would you recommend accomplishing this task?
Old 30th October 2011, 10:46 PM   #14
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
What SY says is correct for the MM preamp part. That's the part that benefits most from a band aid such as a well regulated supply.
Not the MC part and certainly not the White CF which sports excellent PS rejection by design and a 0.1 gain loss...
Unless you'd want a buffered volume control to drive longish capacitive ICs and want to build my ultimate CD volume control using "sucker" parts (just kidding), there is little point in going overboard on the PSU for that section.
The line level preamp will be as transparant as the sum of the parts used. A mild insertion loss (gainwise) but that's all there is to it.
A transparancy from the volume control nowhere near anything you ever heard. There you go, high end audio for not exactly peanuts but at least you know which way to look.
Ciao,
Frank
Old 30th October 2011, 10:59 PM   #15
On Hiatus
SY's Avatar
Just to be clear, we're talking about the line amp. If the cathode of the voltage amp is held at AC ground and the plate load is made high (a CCS, a gyrator, or a good plate choke, for example), the PSR of the first stage can be increased. For example, if you use two red LEDs to bias the cathode and a CCS with a 50M impedance (easy to do), you'll get about 75dB more PSR. The CF will then be the limitation, with a PSR of roughly 26dB. That can be improved by bootstrapping via another tube section or a MOSFET.
Old 31st October 2011, 12:41 AM   #16
I need to do more reading after my midterms are over!
Old 9th September 2012, 07:34 PM   #17
Yaho is offline Yaho  United States
Default please show me the way!
HTML Code:
SY, I hear you but I can't understand what you are saying. Would elaborate for me? What i am hearing is to trap 2 diodes for each cathode instead of a Rk. Am I hearing you right? If so what type of LEDs?
Further, what do you mean by 50M impedance?
HTML Code:
I am not getting what you are saying. ..Your lips move but I can't hear what your saying I ... have become...
Thank you!
Last edited by Yaho; 9th September 2012 at 07:37 PM. Reason: I needed to add a sentence.
Old 10th September 2012, 08:05 AM   #18
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
hey yaho, you build the thorsten line amp many years ago did you not? how did you find the sound?
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 10th September 2012, 08:29 AM   #19
On Hiatus
SY's Avatar
http://syclotron.com/ImPassePreamplifier.pdf
Hopefully, this will be a clearer explanation.
Old 10th September 2012, 11:52 PM   #20
Indeed! You have a great memory! It sounds very neutral. I like it a lot. Here is the link.
RIAA and Linestage for life time
I now want to build a different one. The joy of being a diyer!
BTW, I ended up using a step attenuator instead of the 100k input log.
Me too! It's not about your explanation, it's about my ignorance in the subject matter. I am reading it.
BTW. Are you the author of this article? Wow, incredible!
Thanks Sy!
Frank's Pre Still In Vogue?Hide this!Advertise here!
Frank's Ultimate Tube Preamp. jam Tubes / Valves 464 3rd July 2017 11:23 AM
Frank's 6sn7 preamp losacco Tubes / Valves 9 19th October 2010 05:59 PM
Frank's Tube Database Down? kevinkr Tubes / Valves 6 16th October 2008 09:57 PM
Frank's not gone, his Meat is just dead... planet10 Music 0 19th October 2004 04:34 PM
