| diyAudio Sponsor | ||
I Am wanting to build a Tube Phono Preamp for a friend, and have been looking at the STA1 because He wants bass and treble controls. He also Wants 2 od3 Tubes because mostly of looks but can i use a power transformer with the tubes and make it work also will this amp put out enough power for the power amp. Thanks for all the help.
#2 | |
If the power amp is on a separated frame, you are better to use distinct transformers for the power amp and the preamp but you can also use the high voltage and heater supply of the power amp for the preamp with a cable between them or if they are on the same frame. In that case, you need a voltage dropping resistor to get 220VDC for the preamp supply because the power amp supply voltage is ususally higher. Alain. |
#3 |
It is in a different frame, do you know were i can find a schematic for a more powerful preamp with tone controls? i'm also going to use a power transformer with od3 for the b+
#4 |
if all he wants is visual aesthetics, build a SS phono preamp into a box with a couple of OD3s sitting on top feeding a dummy resistor load.
You'll save a lot of heartache. Alternatively, get a technical rather than aesthetic understanding of what is needed (what is the required cartridge load, what the power amp load is presenting, an idea on the required gain etc) and then ask your first question again. There are a couple of reasonably current "what phono pre should i build?" threads on the forum at the moment - they give plenty of background too
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012 |
#5 |
Its a pioneer turntable some thing like a pl-150 running to a 6550 stereo amplifier.
Amp has 4 6sn7 tubes and 4 6550 tubes |
#6 | |
This tubes phono preamp look nice : ![]() If you plug it to the STA-1 input, change the volume control for a 50K and add a source selector, you will have a complete preamp for any power amplifier because is output is a cathode follower stage. ![]() You really don't have to use a OD3 regulator tube for a preamp, just a simple supply with a good CRC or CLC filter will do and a DC supply for the heaters ... You also don't have to use the zeners and R12, C10, C11 of the phono preamp if you have a well design supply. The supply of a tubes preamp don't need to have the exact voltage to work very well, even if there is some line voltage variations, you will not notice any change and since the current of the preamp is very low and stable, there is no need for a load regulation, just a good ripple filtering is OK. A total of 6 double triodes for magnetic phono and also any number of auxiliary for CD, radio, etc ... The best is using shielded tube sockets to avoid hum because phono input is very sensitive. You can also use small DIP relays to select sources near the RCA plugs at the back, with just a cheap rotary selector to select the DC coil relays, the unselected relays put the corresponding sources outputs to ground to avoid unwanted interferences like in any good sound system ... Another possibility is to look at the commercial preamp section of a well know complete amplifier and reproduce only this part, there is hundreds of them on the WEB. Alain. Last edited by Alain Poitras; 29th October 2011 at 04:38 AM. |
| Running a tube preamp into a solid state preamp? | Pckid212 | Solid State | 3 | 26th November 2009 02:45 PM |
| Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps | MartyM | Tubes / Valves | 3 | 16th October 2008 04:52 AM |
| Guitar Preamp = MIC Preamp = other preamp ,,are they all same? | Paswa | Solid State | 1 | 12th March 2008 05:16 PM |
| twisted pear Preamp/other suggestions for Preamp kit | LukeDuke | Chip Amps | 1 | 1st February 2008 09:57 PM |
| Electret mic preamp - will phono preamp work? | darthmullet | Analogue Source | 6 | 12th October 2007 07:32 AM |
| Page generated in 0.09264 seconds (77.56% PHP - 22.44% MySQL) with 10 queries |
