my first tube amp is running (sort of)- help kill the hum
Old 7th September 2003, 10:12 PM   #1
needtubes is offline needtubes  United States
Exclamation my first tube amp is running (sort of)- help kill the hum
Hello all-
In the mean time of waiting for Ashok's results from his new tube/SS hybrid amp, I decided to break out my 6GM8's and have a go at getting a circuit up and running with one of them. In the past, I have never been very successful. My attempts never gave good enough output for my headphones. This time, I have sound, and it is pretty nice, but could be better... There is a small amount of distortion in the mids/highs, but it isn't bad. Bass is smooth and warm. My main complaint is the amount of hum I have picked up. It is a midbass hum, maybe 100Hz or so. The entire amp is "breadboarded" so, that may be my problem. The hum completely dies when I disconnect the tube from the opamp input, so I know the problem definitely lies with the tube. Attached is the exact circuit I am using. If you see anything I could do to reduce my hum issue, let me know. Thanks all.
Note on diagram: I did this in a hurry. A lot of the symbols are not normal symbols- ie the opamp and diode bridge... I know they are not the correct ones to use, but they filled the space.
EDIT: The 9-0-9VAC tranny is from an old CD-player. The 9VDC tranny is a RadioShack wallwart. Resistors are 1/4W generic metal film, film caps are polyester, generic electrolytics. If any of that mattered...
Old 7th September 2003, 10:31 PM   #2
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Use a full wave, well regulated DC supply for the tube's heaters and your hum problem should be gone.
Frank
Old 7th September 2003, 10:41 PM   #3
I had a feeling the hum problem probably came from the heater supply, as it usually does... I don't have another tranny right now that will put out the right voltage into enough current... so I got the 9V wallwart out of the closet. I will be buying another tranny soon and will try it that way... Thanks
EDIT: the 1k resistor in the heater supply should have been a 10-ohm anyway...
Old 7th September 2003, 11:26 PM   #4
Tube_Dude is offline Tube_Dude  Portugal
Tube_Dude's Avatar
Default Re: my first tube amp is running (sort of)- help kill the hum
Hi needtubes
The hum comes from the not well smothed supply...you must put a RC decoupling in the upper side of the 10K resistor...
As it is , the hum from the supply pass through the 10 k resistor and is amplified by the op amp...
Cheers
Jorge
Old 7th September 2003, 11:38 PM   #5
fdegrove's Avatar
So?
Wouldn't it be best to tackle it at the source iso of carrying it around the PS?
Frank
Old 10th September 2003, 03:32 PM   #6
richwalters is offline richwalters
richwalters's Avatar
Default tube hum etc
Hey there, Just a passing note: Alot of modern made tubes in recent times (to save costs) have differing internal heater contructions. Take the RCA 7199 for example.a brilliant allround audio performer but I found hum on this tube can be a pest to eliminate. Substitute tubes made in recent times use straight heaters, the EF86's and early 7199's used a spiral heater spec designed to bring hum & noise to low spec. Now I'm using Sovteks and other makes
and I'm now finding (somewhat oddly) that putting minus 10 volts on the heater centre tap completely cures my problem. Lift the hum balance wiper off ground and connect to low noise DC source and experiment)
Don't take it for granted, I've also tried positive volts......which by laws of physics should be better, but not always...It pays to do a lash-up and see.
keep it up
rich):
Old 10th September 2003, 04:47 PM   #7
On Hiatus
SY's Avatar
Dumb question: is your heater supply really configured as drawn? You're running AC to an electrolytic cap?
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 10th September 2003, 08:43 PM   #8
SY- The heater supply is a 9VDC wallwart transformer- not AC.
Old 10th September 2003, 08:53 PM   #9
On Hiatus
SY's Avatar
Ah, OK, the transformer symbol confused me. I'd certainly double check the ripple at the filament and look at how the filament ground is being run with respect to the signal grounds.
Old 10th September 2003, 11:13 PM   #10
Positron is offline Positron  United States
Default distortion mids and highs
This circuit looks similar to Benn's, posted sometime earlier.
With 12 volts and a 10k plate resistor, distortion will be present. Voltage needs to be higher, say 35 or 40 volts.
I take it the 1k in the filament supply is a typo. Probably 1 ohm?
With only one filter in the main supply, even though it's 2200uf, hum will probably be a problem.
Hope this helps.
my first tube amp is running (sort of)- help kill the humHide this!Advertise here!
Running Tube Amp Construction PassFan Tubes / Valves 138 12th January 2012 05:39 AM
Running stereo through a single tube with dual triodes? RockysDad Tubes / Valves 2 21st January 2009 12:47 AM
What advantages running ported midbass if you are running a sub? mitchyz250f Multi-Way 3 20th May 2008 02:34 PM
Running planar transducers with a 300B SET tube amp? Rodango Planars & Exotics 1 4th April 2008 06:59 PM
What is this.. some sort of sub? bluedog00 Subwoofers 5 12th September 2007 11:26 AM
