diyAudio Sponsor
View Poll Results: How many Watts, less than?
50W 19 45.24%
100W 13 30.95%
150W 2 4.76%
200W 2 4.76%
250W 2 4.76%
300W 1 2.38%
350W 3 7.14%
Voters: 42. You may not vote on this poll
Old 26th October 2011, 09:05 PM   #1
M Gregg is offline M Gregg  United Kingdom
M Gregg's Avatar
Lightbulb Just for fun power poll!
Here is an idea just for fun.
How many watts does you amp take from the mains supply at idle?
(no music).
It's easy measure the AC current x by the AC voltage.
List type of amp PPP, SE, etc and tube type.
It's easy to do...without stripping the amp!
M. Gregg
What is the sound of one hand clapping?
Old 26th October 2011, 10:00 PM   #2
M Gregg's Avatar
Just to give an idea,
I have a very small SEP 2 x EL34 1 x ecc83
Current is .315A x 245V = 77W
The above are genuine values, just for fun how many of us actually know?
M. Gregg
Old 26th October 2011, 10:22 PM   #3
Send a message via AIM to DigitalJunkie
My ST-70 says 175W,IIRC.
My smaller PP 6V6 Amp,I'm not sure,I've never measured it. But,the primary of the power trans is rated 0.92A @ 117V,which would be ~107W (max),if my line were 117V.
Old 26th October 2011, 10:27 PM   #4
Tony is offline Tony  Philippines
Tony's Avatar
Send a message via Yahoo to Tony Send a message via Skype™ to Tony
i used a kill-a-watt to measure the idle power:
this is a 16 KT88 triode mode pp amp sans overall negative feedback:
Old 27th October 2011, 01:01 AM   #5
adason is offline adason  United States
adason's Avatar
I use bruce rozenblit otl tube amp for satelites, which idles at 230 watts,
plus negligible 5 watts solid state for sub.
Old 27th October 2011, 06:46 AM   #6
My 6AS7 gives me about 2x8watts for sound, and about 80watts of heat, for a total just under 100watts
Old 27th October 2011, 08:41 AM   #7
M Gregg's Avatar
Tony,
I am reading correct 451W?
Sorry should have made the poll higher..LOL
Great amp though!
M. Gregg
Old 27th October 2011, 08:43 AM   #8
M Gregg's Avatar
Some great info so far!
It would be interesting to know the less than 50W that have been voted,
My pre draws 35W and its only 4 x ECC88.
M. Gregg
Old 27th October 2011, 08:54 AM   #9
Tony's Avatar
Originally Posted by M Gregg View Post
Tony,
Great amp though!
M. Gregg
hi Gregg, i had to back down a bit on the bias at -50v, at first, i set the bias at -47volts and this was the reading:
Old 27th October 2011, 09:00 AM   #10
M Gregg's Avatar
Do your house lights dip on power up? LOL
Great piece of engineering.
M. Gregg
Just for fun - Measuring power output ben12345 Car Audio 4 26th February 2010 07:15 PM
Big Tripath power fun on ebay amt Class D 213 24th April 2009 12:07 AM
Page generated in 0.12436 seconds (79.98% PHP - 20.02% MySQL) with 12 queries
