diyAudio Sponsor
Old 25th October 2011, 05:44 PM   #1
Default Newbie- Tube Testing RF Amp tube
I am replacing a pair of 6293 (similar to 6146A) for my ham HF tranceiver. On testing a batch of NOS 6293 on a Hickok 539C, I find the occasional high outlier. Most of them test around 8800-1000 Gm with plate currents around 55-65ma (tube data shows min Gm 4600). Every once in a while I find a tube with real high Gm values almost double ~ 17,000 with lower plate current ~50ma. Is this due to a bad tube oscillating? Any special technique to test such a tube?
tia
jerry
Some general tube questions from a Tube newbie !! Minion Tubes / Valves 11 6th March 2010 01:38 AM
Tube Amp Kit for newbie starro Tubes / Valves 32 17th July 2008 01:37 AM
Harmon Kardon tube amp kit testing diamondsouled Tubes / Valves 10 8th April 2008 02:07 AM
Your favorite tools for testing when building a tube amp rokali Parts 3 20th October 2007 11:50 PM
learning, building and testing tube amp fragman56 Tubes / Valves 103 11th March 2003 10:53 PM
Page generated in 0.06023 seconds (64.14% PHP - 35.86% MySQL) with 10 queries
