diyAudio Sponsor
Old 25th October 2011, 09:59 AM   #1
Skorpio is offline Skorpio  Denmark
Default Mono sub-out from one trafo?
To prevent hum in my long connection to my active subwoofer, I am considering a galvanic seperation (trafo).
Could I use a single trafo (e.g. Lundahl 1517) with two primaries, to make the L-R summing and then use one secondary to sub-out?
Will this give any problems?
http://www.lundahl.se/pdfs/datash/1517.pdf
Old 26th October 2011, 01:24 AM   #2
Chris Hornbeck's Avatar
If you can drive the transformer with a low source impedance to the left and right main channels and include "build-out" resistors in series with the transformer primaries, your plan will work out well. I'd recommend build-out resistors much larger than source impedance (for interchannel isolation) and paralleled secondaries.
Many years ago transformers were sold for the purpose of high-level (speaker level) mixing for a summed center channel speaker. These were used without any build-out resistors.
All good fortune,
Chris
Old 26th October 2011, 06:07 AM   #3
Thank you for you reply...but there is something I don't understand:
The drive is Pass B1, with 270R in series with output. What are those "build-out" resistors? If placed in series with primary, the will increase drive resistance? Are they for seperating channels at pre-output? What values recommended?
I could parallel secondaries for 2:1 operation...subwoofer load/input is 33kOhm and 5 meters RCA wire...
Old 26th October 2011, 08:01 PM   #4
"Build out" is a name for series resistors used to isolate the two channels from each other. But, if you're only going 5 meters, I'd instead recommend running your sub's power cord through an extension cable back to the location of your preamp, dressing the wiring *together* (counterintuitive, but usually correct) and feeding signal from a simple resistive Y. Maybe about 27K series' ("build-out") to a single 270R shunt. Even *much* bigger resistances won't be a problem at sub frequencies. If the sub has stereo inputs, you won't even need the Y. Just a thought.
All good fortune,
Chris
Power supply options.. bigger trafo with less caps or medium trafo with heavy caps? rhythmdiy Chip Amps 9 23rd October 2007 12:30 AM
difference between mixed mono and summed mono Clipped Car Audio 4 10th October 2007 11:34 AM
making dual mono jack from single mono jack dubmunkey Analog Line Level 2 12th October 2006 02:16 PM
Help with trafo Hojvaelde Tubes / Valves 1 13th February 2006 08:12 PM
Dual Mono - Anti Mono Power Supplies pmkap Everything Else 3 16th February 2002 05:10 AM
Page generated in 0.08285 seconds (75.20% PHP - 24.80% MySQL) with 10 queries
