| diyAudio Sponsor | ||
I'm going to run a pair of Sylvania 6V6gta at about 420V on plates, basically a Fender Deluxe Reverb power section (about 22W 6V6 pp power amp). The point is I wanted to use diode rectification, but it seems it's not possible doing this (even with right bias). It can be done with tube rectification, but I've read it's bad for the 6V6's with diodes. Must be something to do with max current through output tubes at max power, don't know well, really.
Any suggestions? |
#2 |
The only issue I can see is if you have a tube rectifier design and you switch to SS without compensating in the power transformer, you will not be running the 6V6s on 420V B+, but something higher as the tube rectifier has tens of Volts of diode drop.
If you choose the proper transformer to set your B+ at 420V, it should not matter. You amy get more rectifier noise with the SS recifiers, but snubbers and proper filtering should take care of that. |
#3 |
Slideman: Model up your power supply both ways in PSUDII; that will show you the difference between SS and tube rectification, and you'll be able to quickly determine what transformer secondary voltage you need for SS rectification vs. tube rectification.
One other difference between the two is that SS rectification will be instant B+ to the tubes (no slow warm up as with tube rectification), and the SS rectification will provide lower PS output impedance, which in a guitar amp, may or may not be a good thing if you want voltage sag at high output. |
#4 |
I have to order the power supply, but had doubts if it was going to fry the output tubes! Great tips, btw! Just have to place 100uF 450V caps and that's it, I think!
#5 |
Using fixed bias and relatively low idle current, it should be fine. When exceeding one rated parameter, don't push the others...
#6 |
#7 |
COnsidering that Leo Fender ran the 6V6s at 100v over the book ratings, and those amps are still running 50 years later, I am betting you can get away with it too.
#8 |
yeeeeeeeeeeeeah! But my doubt was if that was possible because of tube rectifier, but now I know I can use diodes! Just that.
#9 | |
In those old days (well perhaps today also) the amps with the biggest number sold easier than the one with lower numbers. So squizing 22-25watts out of a pair of 6V6s ment more sale. It may also be the it gives preferable tone, but certainly it is possible to design with tube's life in mind in these days of mic'ed cabs and megawatt PAs. So my suggestion is why not make it into a cathode biased version and live safe? |
#10 |
I thought cathoded bias made tubes life last less than fixed bias. 22W can be cranked really good, and using high SPL speakers will make this puppy rock like it should for local gigging! 50W is a lotta power, I'm trying to make friends understand this.
| Why high voltage Fets when low voltage types gives less distortion? | Circlomanen | Pass Labs | 21 | 9th December 2009 09:43 PM |
| Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. | kimbal | Tubes / Valves | 4 | 11th May 2009 08:05 PM |
| 6BY5 High Voltage & High Current Choke Input Design P.S. | snoopyma | Tubes / Valves | 7 | 28th June 2006 01:32 PM |
| 6v6. 6lg Gain Max Voltage | mrhotmark | Tubes / Valves | 1 | 2nd December 2005 08:55 PM |
| 6V6 SE and Screen Grid Voltage | zxx123 | Tubes / Valves | 5 | 2nd February 2005 05:36 PM |
| Page generated in 0.09722 seconds (77.52% PHP - 22.48% MySQL) with 11 queries |
