VTL deluxe 100 monoblk (KT88) need help?
Old 4th November 2011, 12:44 PM   #31
costis_n is offline costis_n  Greece
Look the idea is there roughly 3 classes in descending order of dissipation
(kt88 - 6550)
(EL34 - KT77)
(6L6 - 6p3se)
You should keep it in the class it was designed for. My advice is , if you are sure it ws meant for EL34's, and you need something within budget, go for JJ KT77's. Their quality control issues were solved a long itme ago, now they are fine, I have some myself. They sound very good to me.
Old 4th November 2011, 08:46 PM   #32
ecir38 is offline ecir38  United States
ecir38's Avatar
found some info on bias and schematics. For starteres make sure your amp uses 10Ω resisters on the cathodes to measue bias. You should be able to measure the resistance at the bias port to ground with amp off. Bias your KT88s accordingly then give another listen.
I would contact VTL with your serial number to see if they can provide you with the book on this amp.
Audio Asylum Thread Printer
Old 4th November 2011, 08:48 PM   #33
TheGimp is offline TheGimp  United States
TheGimp's Avatar
KT77 bias is slightly different from EL34. Although you still need to adjust bias even if you are putting in a new set of EL34s.
Old 5th November 2011, 11:52 AM   #34
About the same differences from between different brands of EL34, yes.
Old 31st January 2013, 03:33 PM   #35
Sgkho249 is offline Sgkho249
Hello everyone, I am a bit nuts I think. just order 10pcs of 6p3s and not the 'e' version. Will it be able to hold the plate/cathode voltage.
VTL deluxe 100 monoblk (KT88) need help?Hide this!Advertise here!
EL34, KT88, High Voltage?, VTL.. kegger Tubes / Valves 28 18th August 2015 08:25 AM
vtl deluxe 300 mb namseok Tubes / Valves 0 13th March 2007 12:17 PM
VTL Compact 100 Monoblock x 2. sstong Tubes / Valves 4 17th October 2004 04:49 AM
VTL deluxe 300 amps - adjustment question audiomatic Tubes / Valves 7 23rd June 2004 08:23 PM
Copyright ©1999-2017 diyAudio
