VTL deluxe 100 monoblk (KT88) need help?
Old 31st October 2011, 08:23 AM   #21
Defiant is offline Defiant  United States
Defiant's Avatar
The 12AT7 (ECC81), 12AX7 (ECC83) and 12AU7 (ECC82) all share the same pinouts. Since the low level stages in a VTL are cathode biased (and probably cap coupled) then an incorrect tube will work with varying degrees of success. Nevertheless, the cathode resistor and plate load resistors were chosen for a 12AT7, and that is what will work best.
Likewise, the 6550/KT88 and EL34 share a similar, BUT NOT IDENTICAL, pinout. Generally, a 6550 or KT88 will work in an EL34 socket, but not necessarily the other way around (it depends on whether pin 1 of the 6550 socket is grounded or not). Likewise, they have similar transconductance and similar bias points. That is why the previous owner was able to run KT88's in place of EL34's. That doesn't make it the best setup though - optimum plate loads for the two types are different.
Also, the DeLuxe 100 should be a fixed bias amp, which means that you will need to set the bias for a replacement set of tubes. Hopefully you know how to do so, and what the settings should be. 21khz and I agree on the use of SED EL34's. Besides sounding good, they are a tube I know for a fact won't complain when running 500V on the screen. Some lesser EL34's can have... issues.
Old 2nd November 2011, 02:43 PM   #22
ecir38 is offline ecir38  United States
ecir38's Avatar
I would try the 6P3S-E from Jim Mcshane and bias them for around -25w dissipitation. Great tube at a great price. If you lke them stock up while they last.
Tube & Information Page
Brad
Old 2nd November 2011, 03:15 PM   #23
costis_n is offline costis_n  Greece
But 6P3S-E is supposed to be an 6L6 copy, no?
Old 3rd November 2011, 04:43 PM   #24
ecir38's Avatar
Yes, a heavy duty version. From the above post it looks like the amp was suppose to have EL34s in them but he had KT88s in them. If this is the case than the 6P3S-Es should work fine.
I would buy from Mcshane, he weeds out the bad ones. Contact him and he could probably send you matched sets that have cold or hot bias acccording to the amp you use.
With the amount of tubes this amp uses it's a nobrainer. If you like them at this price point I would stock up for years to come.
Brad
Old 4th November 2011, 02:34 AM   #25
Defiant's Avatar
You do realize the 6L6 is nowhere near a correct replacement for an EL34, right? Different bias requirements, different drive requirements, and different load requirements. It may work, but it will probably sound like a$$.
Old 4th November 2011, 02:48 AM   #26
ihear21khz is offline ihear21khz  Malaysia
I have heard a current production 6L6 in an amp designed around the EL34. It does sound like a$$!!! You really can't achieve great results/sound by trying to save a few bucks and not buying the correct tube.
Old 4th November 2011, 03:46 AM   #27
ecir38's Avatar
I wouldn't have recommened this tube if I haven't tried it in both KT88 and EL34 amp with great results, can both of you say the same.
The OP used KT88 for years, if it didn't sound good do you think that would be the case.
If this amp allows the user to adjust the bias I don't see the problem. If it don't he looks like he is willing to get his hands dirty so all he would need to do is change the cathode resistors accordingly.
skho249, do a search on audio asylum to get more info on this tube since it's capabilty was discovered there.
Brad
Old 4th November 2011, 09:05 AM   #28
Sgkho249 is offline Sgkho249
Isn't 6L6 has a 6.3v, 0.9amp. same as el34. But what's the plate voltage on both. Also 6p3s-e it has some good reviews on audio asylum where they replace el34 on a dynaco st-70 and seems that they have stock up with more 6p3s-e.......
Thanks Again Defiant
Those 6p3s-e are really affordable!!!
Old 4th November 2011, 09:24 AM   #29
Brad
Hi Brad, thanks for the info. Yes I did look at the audio asylum on those 6p3s-e. For the price I also think that there shouldnt be any compliant, if it can fit into my VTL. In the VTL it has individual tube bias and also a central bias port. But I'm not sure how to bias an amplifier.
Yes I'm willing to get my hands dirty, and will try to locate the cathode resistor ASAP.
Old 4th November 2011, 11:10 AM   #30
Defiant's Avatar
I've been there and done that. As a general rule the 6L6 doesn't work well with the lower P-P impedance of the transformers typically used with EL34 and 6550/KT88 designs. They also have less gain than EL34s, 6550's, and KT88's.
6L6's, EL34's, 6550's and Kt88's all have 6.3V heaters. 6L6's only draw 0.9 amps of heater current, while EL34's draw 1.5 amps. The 6L6 types have smaller cathodes and cannot supply the peak emission of an EL34.
You can try the 6P3S, but I don't think it is going to give the best sound with the VTL's 4K OPT's. Hopefully the VTL has enough bias adjustment range and gain - the 6P3S and 6L6GC's need more negative bias and more voltage swing from the driver.
VTL deluxe 100 monoblk (KT88) need help?Hide this!Advertise here!
EL34, KT88, High Voltage?, VTL.. kegger Tubes / Valves 28 18th August 2015 07:25 AM
vtl deluxe 300 mb namseok Tubes / Valves 0 13th March 2007 11:17 AM
VTL Compact 100 Monoblock x 2. sstong Tubes / Valves 4 17th October 2004 03:49 AM
VTL deluxe 300 amps - adjustment question audiomatic Tubes / Valves 7 23rd June 2004 07:23 PM
