| diyAudio Sponsor | ||
Dear folks,
I wonder how the graphs in most datasheeds exeeds the limiting values. As example the ECC82 from JJ show a graph for Ug1 = -20V which ends at Va = 400V. The limiting Value for Va is max 300V. Same situation for Ia which reach 23mA and the limit is 20mA. Does this means, that the limiting values given by the manufactor should not be reach in run mode but can exceed for a few seconds without to break down the device? For "sand" devices means exceeding the limits the absolute death of them... ![]() So if I want to measure Ia/Va/Vg curves I can do this by exceeding the limitings by say ~ 30% for Va and ~5% for Ia ? But how long is this allowed without to destroy the tube? Thanks for your help and sorry for this real basic question.. Regards Karsten |
#2 | ||
Often the plate voltage can exceed twice the B+ in a tube stage that is misloaded and ran into hard clipping. This can be the case in a guitar amp, and it does lead to fried parts.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#3 | |
Some curves graphs already include a maximum plate dissipation line but you can draw it yourself easely. For each plate voltages on the "x" axis, you calculate the plate current ( Ia = Dissipation / Va ) and mark it on the grid, then, you just have to reliate those points with a line to get the dissipation limit curve. In a class "A" amplifier stage, the current don't vary much at maximum power but in a class "AB" or "B" push-pull power amplifier, it is much greater at maximum power than with no signal and you have to consider that for the operating point choice. It is alway better to stay under the limits for longer tube life, specially the maximum plate dissipation over which the tube can fried, I consider about 10% less than datasheet maximums is safe. The maximum plate voltage is to avoid arcing between electrodes and is less critical. Alain. |
#4 |
And keep in mind that data sheets are intended for engineers to use during design. Within those specs, the manufacturer expects the tube to have a reasonable lifetime of reliable service. The specs are not indicators of just where a tube will fail. They don;t recomend a tube be run over 300v, but that doesn't mean that the tube will fail at 301 volts.
| Intermodulation Distortion Values below THD Values by SS Amps - is this possible ?? | tiefbassuebertr | Solid State | 28 | 30th May 2011 11:20 AM |
| 6N3P-EV measured Ia/Va/Vg curves | rotaspec | Tubes / Valves | 2 | 2nd January 2011 08:02 PM |
| Transformer VA versus output power VA | nigelwright7557 | Solid State | 8 | 18th May 2008 02:57 PM |
| WTB: NuForce IA-7 V2 | cartman | Swap Meet | 0 | 17th September 2007 07:09 PM |
| Page generated in 0.08713 seconds (77.38% PHP - 22.62% MySQL) with 10 queries |
