| diyAudio Sponsor | ||
I got a Rev.B board last year that had been populated in 2003 I believe. Never been powered up, and I've had it sitting for nearly a year as I can't decide if I want to build it or go to a SS power amp with a tube pre. Anyway, what's your opinion of powering this board up as far as the electrolytics are concerned? Swap them out at this point? FWIW, I don't have a variac so that's not an option.
#2 |
Light bulb trick?
Eli D. |
#3 |
#4 |
работник
9 or 10 years since manufacture is certainly marginal for good sound.
If they are decent quality, you can still use them, with the Panasonic method of restoration: Use a high-power series resistor to limit the leakage current (start with 47K 14W, say). Apply 200 to 400Vdc for a minute, and watch the voltage across the resistor drop. If the leakage current you measure falls to the rated value, they should be safe. Panasonic, Nichicon are good enough quality to give this a try. Caps with odd names, and Illinois (IC) TTA series etc are often poor, and not worth even a small amount of trouble. |
| ST-35 First Build | milsman2 | Tubes / Valves | 44 | 23rd May 2012 09:39 PM |
| New Dynaco Design DIYTUBE Stereo 35 Power Amplifier | garyroach | Swap Meet | 1 | 23rd June 2011 01:06 AM |
| New Dynaco Design DIYTUBE Stereo 35 Tube Amplifier | garyroach | Swap Meet | 0 | 19th June 2011 05:16 PM |
| St 35 or St 70? | scetoaux | Tubes / Valves | 13 | 19th February 2011 05:18 PM |
| FS DIYtube ST-35 parts kit | Jed | Swap Meet | 2 | 8th January 2007 03:28 PM |
| Page generated in 0.07798 seconds (74.49% PHP - 25.51% MySQL) with 10 queries |
